Disabling Electronic Sound Enhancement and ANC for subwoofer install
DarkkMatter
Virginia, USA
I just never noticed a difference with ANC or ESE in the GT when driving it, but I knew it was absolutely necessary to disable it if you plan on getting subs, b/c will emit buzzing/crackling sound from what I researched on car audio sites.
In my RAM Rebel I got system put in and they forgot to disable ANC. Lemme tell you it sounded terrible. Got it disabled and much better. IMO, disabling it makes your radio and speakers sound better b/c those extra frequencies being pumped through it are no longer there.
Luis S.
Luis S.
Austin TX
2024 Mustang GT PP1
I got a bypass harness for the anc, from what I've read I will need to use forscan for the ese. Going to do a little research before I try it.
Wouldn’t be the first time a media release was incorrect.
First you ask for a reaction, you got a reaction. Then you ask for the source, you got the source. Then yoi ask for proof with a link, you got the proof with the link.
And then you say that it could be a mistake by Ford. 🤣🤣🤣
Something lost in translation?
Don't use Google translation then.
Is it possible the media release didn’t translate correctly? The owners manual mentions exhaust sound enhancement and even talks about the electronic noise reduction function and you still wanna disable a head function in order to prove a point?
Even when something is in front of your face, you still feel the need to deny.
Even discovery requires confirmation
are you attempting to claim the german media release proves imitation engine / performance sound is played in the mustang coupe gt?
Are you trying to invent the wheel while its already invented?
All of you who are disabling ESE, can you simply record driving in track mode, maybe a hard acceleration run, before and after disabling, and pickup the difference in audio?
I still remember the very first time I went from idle to a full throttle blast in Track Mode at high rpm (tires spinning), just a short blast - I remember my kid asking, "What was that?" referring to the sound. It is definitely electronically enhanced in the interior, and was almost like an on/off switch on this high volume blast of sound . . .
Does the dark horse get excluded?
You would think (hope)... but alas, no... ESE is clearly spelled out in the order guide for the Ecoboost and the GT, but not for the DH... though every DH asbuilt file I have looked at has ESE enabled!
Mine is the Dark Horse, and it pretty clearly is noticed at the extreme (Track Mode, 6-7000 rpm full throttle) that something electronically enhanced is going on. It is not so seamless as to be "real" - this sudden blast of noise
Silverstone
2025 GT 6spd
Are the ANC mics present even in cars where ANC is disabled from the factory? Meaning, those of us with ANC turned off in module 727-01-01 from the factory, can we get ANC working simply by turning it on with Forscan?
Luis S.
Luis S.
Austin TX
2024 Mustang GT PP1
So I talked to my Ford mechanic, he said he should be able to disable the Fake engine noise with the Ford FDRS (Ford Diagnostic and Repair System) .
