Check the oil level on your new Mustangs ASAP
Germansheperd
I have 155 miles on my 25 DH and decided to pull the dipstick. The level was barely and I mean barely touching the lower dot. I put a 1/2 qt of oil in it and it now registered right in the center of the cross hatch area.
I had heard Ford is shipping these things ‘low’ on oil and it appears how you look at it the levels are 1/2-1 qt low from the factory.
TonyP66
Illinois
2025 Dark Horse
I bought a 2020 f150 a few years ago with about 35k on it. First oil change shocked to see no oil on the stick.
Brought to the dealer and they adjusted a few things, couple months later same thing.
Turned out crankshaft had issues with the seals. They put in a full block for me new from factory under warranty, no issues since.
I also have a German Shepherd, coincidence???
hoodscoops
NY
DH, Sti
How did you get the dipstick out without buring your hands on the bracem
That's disappointing, to say the least. :facepalm:
Curious, I read Ford's Pre-Delivery Inspection checklist. While the attached specifically says check the windshield washer bottle and coolant reservoir, it says nothing about checking the oil level. That's a fail. It does say check all under hood components for leaks. Someone might have very well done that. And seen nothing. But it's not the same as checking the dipstick, is it?
Glad to hear you got things sorted. :whew:
https://www.mustang7g.com/forums/threads/new-car-acceptance-checklist.158844/
Germansheperd
Germansheperd
I did 20 years in the car business if you think PDI exists you are grossly mistaken. Ford may have a procedure and a checklist but that doesn’t mean it is done.
Mark off the sheet, turn it in and then move on and lie about the next one.
Percys650DH
Covington, LA
My DH was the exact same, half a quart just to get it in the middle, barely touching the minimum safe mark. Couldn’t believe they would do that and call it good
JohnWimsey
Oklahoma
2025 Dark Horse
Top dot is full mark above top. Dot is overfilled.
Germansheperd
Germansheperd
It is the new ‘norm’ I guess.
ChitownStang
Chicago, North Shore
2015 Mustang GT Premium
Did oil change myself at 1150mi. Emptied 9 quarts
JohnWimsey
Oklahoma
2025 Dark Horse
I put 10q of full synthetic.
So not to start an oil argument, if it reads full synthetic, it’s synthesized conventional oil with a changed molecule. If you wanna run a true synthetic oil, the bottle needs to read synthetic oil like Royal Purple or Amsoil. . Both about the same and give outstanding lubricant properties.
