Car sways back and forth during start up [ Video ]
JAM486HP
I think a trip to the dreaded dealer might be unavoidable, though maybe you guys could point me in a direction as to what might be causing this or it's normal.
First video at startup on a level surface, vehicle in Park, without the brakes applied, it rocks back and forth as soon as the engine turns. Been doing this since day 1.
Second video this time in Neutral without the brakes applied, the car rocks about 6 seconds after startup. This I only just discovered by starting in different scenarios, parking brake on, no brake, remote start etc..
A10, no strange noises, no lights or codes and the car runs great
Startup in Neutral no brakes applied
Ciulster
Alberta
2024 Ford Mustang GT
I know what the problem is! Your car came with the wrong transmission! 😁 Joking aside, that looks like it might have something to do with parasitic forces moving through the driveline. I once jacked up the rear end of my truck and even though the transmission was in neutral it was able to spin the rear wheels up to about 10mph at idle, I was able to stop it by hand though.
These cars are fairly high horsepower but even still there shouldn't be THAT much power being sent to the wheels while out of gear. If indeed the startup flare is enough to move a 4000 pound car a bit through parasitic transmission forces alone I'd be concerned my transmission was built with some tolerance out of spec and it's dragging power out of it to the rear wheels somehow. Might want to at least get the dealers opinion on that and see if it's normal. Not worth it to keep driving it if the trans is assembled wrong and will eventually burn up.
JAM486HP
JAM486HP
My initial order was manual, then my old wrecked knees talked me out of it.
Yeah I try to avoid dealerships like the plague. Probably should get it on record. The initial startup movement in Park I figure was just a lot of horsepower fired up would make the car move a little. It's been doing that from day 1.
The one that really puzzles me is startup in neutral and the car moves 6 seconds later.
Ciulster
Alberta
One thing to note too is modern automatic transmissions do do a lot of weird things behind the scenes. Might be something like the transmission doing a start up self diagnostic check and after 6 seconds it's engaging a clutch pack or a valve body solenoid or something and even though it's in P or neutral that's enough to let enough power through to move the car without brakes on. Every electronic solenoid Dodge transmission I have ever seen from about 1993 and up when you put it in reverse, like clockwork, wait 3 seconds, it buzzes for 2 seconds in a way that sounds like someone running their nail along a metal file. Something to do with solenoids or something. Just the way they operate.
Ciulster
Alberta
Another thing to note too is maybe ask the dealer to verify your park brake is setting correctly. If I understand the owners manual correctly the park brake should automatically set and stay set with the car running and should not disengage until shifted into a moving gear. Same how the hills start assist and hill hold is supposed to hold the park brake on until it detects the clutch being let out and a little throttle being applied. This might be a normal running condition of the car that is normally masked by the parking brake being engaged by the computer for startup
JAM486HP
JAM486HP
This is all great information. I wondered about the auto hold feature, I have it disabled though sometimes on a cold start it will be activated until I accelerate
Barstoolman
Thousand Oaks, California
Mustang Dark Horse
Mine was doing the same as yours in the first video, besides all the other issues. Hopefully a new transmission and replacement shocks will take care of all the noises going on while I’m driving.
Neggytive
Engine starting torque rotates the driveline and the force gets transmitted thru the car, the transmission rotates a couple of degrees on its mounts, as does the engine, the transmission is in park but the shaft still turns that couple of degrees til it hits the differential which rotates on the slop in the gears until it takes up all the slop and starts to untwist causing the car to rock back and forth
With the car off and in Park push on it from the back and it will roll forward then back. It id just all the slack being taken up then releasing
Barstoolman
Mustang Dark Horse
I’m finding it interesting that many are playing off the rocking motion as normal behavior for a high-powered automobile. I’m 73 years old, had over 30 cars in my lifetime, most of them high-powered/high-performance vehicles from Chevy, Ford and Dodge. Corvettes from all eras, Mustangs from all eras and Dodge chargers from all eras. I’m curious to know why none of these cars ever did that, but this one does? Does Ford have such a unique set up in the dark horse that the rocking motion can be considered normal?
Regardless, I appreciate all the comments and appreciate Ford for stepping up to install a new transmission for not only the rocking problem, but all the other issues in regards to clunking and trans slippage. Leaking shock absorbers just added to the fun!!
JAM486HP
JAM486HP
I'm with you on this 100%. Many of vehicles as well, never had one rock like this. Dealer said normal behavior for 10r80. I have had my share of issues, such as gear skipping, cant stand that, only solution is Track Mode. Then I have, in all modes, the dreaded, 4th to 5th gear shudder, as well as many times in Sport mode, gears hang. I clear the adaptive tables and it will temporarily solve the delayed shifts.
Dealer has had it twice to check transmission since Ford took away the ability for most of us to check fluid levels without a lift. They claimed they checked fluid levels hot (don't believe it) and said it was full. Report was everything is functioning as "normal". So I will drive it until the warranty is almost up or it breaks down, which ever occurs first.
Pretty sure there is a Ford TSB for this and it is normal. It is to do with the clutch application (there are 3 I believe in the 10R80) and nothing to worry about
Dark Sprite
UAE
I have the 10R80 and none of this happens on mine, so I would not consider it to be normal. I'd suggest you try a few different dealers until you find one whose technicians actually care. By gear skipping do you mean on the way up or down?
