Can the S650 10R80 be tuned to skip more gears?
No, pre selector boxes are old tech in which you select a gear in advance with a normal H pattern shifter, then effect the change with the clutch. Our buses in the 50's and 60's had them.
A great way to freak the driver tester out on a licence test too.
Westphal
Why does that sound like a manual?
Actually, I got that wrong. They used a selector quadrant near the steering wheel. Select a gear, then depress the clutch to change gear.
Ah, so pick a button any button which selects a gear that becomes the active one upon modulation of the clutch. Well yeah if the automated intuition was integrated it might work but then again prindle fixed some of the annoying inherent traits. Me, myself, and i prefer the manual method but since this is an automatic skipshift thread, yes it seems possible however the criteria for majority of operation will need to be considered.
In.
effect, a DCT is like a preselector box too. As in gears are in mesh already, but drive depends on which clutch is engaged.
