Best Tire size for my new wheels
P2
2024 Vapor Blue Mustang GT Premium 401A 6 Speed
So, I'm finally getting around to upgrading my OEM wheels. I've decided to get gloss silver Velgen VF5 for my vapor blue Mustang GT. I'm undecided as to what tire size I should go with. I'm getting 19x10 square setup. The car isn't lowered and I have no plans to lower it. I was thinking about getting 275/40/19's but now I'm wondering if I should go with 285/40/19's. I don't want to go with 35 ratio because I'll be concerned out the gap between the top of the tire and fender and I don't want to go with 20" wheels as I don't want to have to recalibrate the speedometer and plus the ride is better on 19's. So, do any of you guys have a similar setup (19x10 w/ 285/40/19)? If I decide to go with 285's should I be worried about any fitment issues like rubbing? Help me decide... Thanks in advance for your input!
Go 285/35. Why?
285/40-19 is a bit tall for the front at 28"
285/40-19 tire selection stinks. A couple decent tires and then mostly OEM SUV sizes (BMW/Porsche etc)
275/40-19 is a hair narrow on the 10" wide wheels. Works but just looks a little odd.
Cobrakit
Southern Maryland
2019 Mustang GT PREMIUM PP1
Ford put 275x40-19 on DH rear 10 inch wheels. I installed those tires on my front 9.5in front wheels with no issues. I then installed 305/35-19 Pirelli Pzeros to match on rear 10in rims. Granted that's the smallest recommended rim size for rears. I didn’t find a 305x30-19 that would not fit 10 in rims.
OBTW I believe Ford put the 275x40-19s on the rear of the GT Perfotmance Pac rear wheels that where 9.5in as well.
P2
P2
That's great info but, you didn't address or answer any of my questions...
Cobrakit
Southern Maryland
There are many variables to tire fitment. I was just giving you info on Ford factory sizing. You can check the diameter of you current tires to the new ones to see what wheel well gap you will have. Wheel offset also influence the overall look, ie how far the tire sits out. As far as speedo is concerned, it's a function of overall diameter. You need to compare your current diameter and compare to new size. If different it will change speedo, but maybe not by much. Ex 255x40-19 to 285x40-19 is almost an 1 in taller. Maybe 2-3 mph off. Not sure what your current tire size is.
hoodscoops
NY
DH, Sti
Are you on stock suspension? 305 in the rear should have a noticeable wheel gap
Thuggs
Tasmania
2024•5 GT
Speedo can be calibrated thru the dash
zpduff
I was worried about my speedo being off with 285/35r20 but it's exactly dead on. I never checked stock tires with GPS but I will this winter when I put them back on. Assuming it was just off from the factory and I got lucky, I've also seen people post here that the speedo auto corrects for tire size. Still not so sure of that but my larger than stock tires are definitely reading the correct speed without me doing anything.
zpduff
Also I think 20s look better if you're not going to lower the car.
Cobrakit
Southern Maryland
Not if you go with 35 ratio. Diameter close to stock rear tires on DH. 305/35-19 27.40in, 275/40-19 27.66 in (stock rear DH non HP).
I lnow car has more features then i have used, but where can speedo be calibrated thru dash ???
350 Feet
CA.
2018 GT350 J0060
Wheel size has nothing to do with needing to recalibrate a speedo. Overall tire diameter is the key here.
You can make any combo of tire and wheel you want as long as the overall tire diameter is the same(or close) to stock. Don’t want the gap but want some meat on the road; go 20”.
It’s a Mustang, not a Cadillac. IMO
Style, performance or ride quality; can’t have them all…
Cheers,
hoodscoops
NY
DH, Sti
That .3 inches. every inch counts
Cobrakit
Southern Maryland
0.26 in and currently within 1 mph, not going to try FORSCAN to fix. But then i'm not sure how accurate it was to start with. Just happy to find 305s that fit my 10in rims and simliar diameter.
