Battery Tender
longjonsilver
Fargo, ND
2023 Ram 1500 Laramie, 2022 Jeep Gladiator Rubicon
I just bought the battery tender from Ford (https://accessories.ford.com/ford-performance-5-0-smart-battery-charger-maintainer) and I've had it hooked up for over a week now. I came back a week later and still no charge on the battery. It was completely dead when I hooked it up and even now with it charging, nothing really happens. Does anyone have experience with this product to know enough if this cannot charge a fully dead battery?
37.5726028 / -85.1551411
The Ford battery tender looks very much like one made by CTEK which is a very good and reliable tender. I noticed the Ford one has the recondition step, and if after going thru that your battery is still dead, then it may be the battery and not the tender.
Reactions: DCS
DCS
Ocala, FL
When you connect the charger up to the battery, does it have any indication it is charging? A dead battery may not take a "normal" charge. Some chargers can charge a totally dead battery in a "repair" mode. I have no experience with this. Just read about it.
Many/most will NOT charge a battery when it's below a certain voltage.
I posted a recommendation for a charger that WILL not only do that, but also includes a 'power supply mode' - great for when you need the ignition on but the engine not running for long periods of time, such as when you are programing modules using FDRS.
Here's a link to that post: (3) Car's first hiccup: POWERTRAIN MALFUCTION/REDUCED POWER | Page 4 | Mustang7G - 2024+ S650 Mustang Forum (Dark Horse, GT, EcoBoost, GT500, GT350, Mach 1)
longjonsilver
Fargo, ND
I hooked a different charger up to it and turned it to the 50 amp to see if I could get the car to turnvoer, but it won't start at all. I'll probably leave that charger on there for awhile to see if I can get the battery to get a little charge and see what happens. I get the 12v low battery warning, so I wonder if the battery isn't shot. Will see
GripTime
Dark Horse, 2006 Mustang GT
The Ford Charger/Maintainer seems to be misleading. IMO it's not really a "charger" it is just a tender. Battery chargers can usually supply up to 14AMPs. However @roadpilot above is correct in his post.
Do you have a voltage meter to measure the voltage of the battery? Even if that 50AMP boost start is able to start the battery it's likely to still be dead the next time you try and start it. Believe me, I have experience with exactly this! Check the voltage if you can.
longjonsilver
Fargo, ND
The battery I had in my car ended up being bad, so I had to replace it. The dealer wouldn't cover the warranty of a new battery unless I had towed my car into the dealership so they could test it in the car and take pictures in order for Ford to warranty it. Instead of the hassle, I just paid the $230 out of pocket to buy a new Ford battery. Everything seems to be fine now and I hooked up my battery tender to it. Wish warranty work wasn't so difficult as they could have easily tested the battery after I took it out but claim that it could be from a different car
jimgt2k24
Near Detroit
Find a better stealership.
In their defense, the dealership won't get reimbursed for the repair unless they can document that the battery is defective (and it or the car wasn't damaged by the customer).
Saburak
France
DH BLK / 10-Speed / RECARO
I tested two CTEK MXS5 chargers, but they became very hot at +131°F (battery at 20%). The cables also tended to heat up, which seemed insufficient to me. So I switched to a NOCO Genius 10, and now there's no more overheating. Very good product.
MCS
SW Ontario
'24 DH Premium
Does anyone have a video or image on how they hooked the ground up in the Dark Horse? I took a peak under the hood when I was working on the RTR Hood Vent and saw that it is very different from previous gen. Looking to perm install my CTEK so I can plug and walk.
2021 GT PREMIUM (Forgive the dust/dirt - before I got my engine bay clearners)
DARK HORSE
bamberge
Vestal, NY
The hexagonal post that the ground strap is attached to is removable with a socket wrench and your battery tender ground can be attached to there as well. I have attached a picture of the set up on my car.
MCS
SW Ontario
'24 DH Premium
Yeah there is another MEGA THREAD going on where I did the installation just like this. I actually used a box wrench to remove the ground bolt, throw my ground eyelet on there and then do it back up.
Took SEVERAL hours of charging but my battery is now back up to snuff. Ford had the car sitting in a lot for 2 weeks waiting for shipment. Car has only been driven 86km since it was built a month ago lol
