MCS
SW Ontario
'24 DH Premium
Not for that price lol
Shipping to Canada is $136 on top of the cost of the speaker!
Honor
Korea
S650
Hello everyone. I bought new mustang 2.3 coupe with B&O audio system.
It was my dream car when I was young boy, finally I bought it when I'm alsmot 50.
Anyway I found that better suound is expected through replacement subwoofer, today morning,
I changed subwoofer to PIONEER subwoofer
After replacement, during playing speechless, OST of aladin, I touched subwoofer box, however
I could not feel any vibration, even though big low beat was coming.
In my experience, I could feel low beat and sound was stronger in cabin after replacement, but
I could not any vibration of woofer box.
Is tiny or no vibration is normal?
You should be able to hear it working in the boot / trunk
If you got the wiring incorrect the two supplies could be cancelling each other out?
Honor
Korea
S650
My new subwoofer is PIONEER TS-A250D4.
I touched subwoofer cone directly, but I can not any vibration.
And no sound from subwoofer.
But in cabin, I felt that the sound is more lower.
It's so strange.
And I worked with the video in below as a reference.
But in this video, I can not learn how to wire.
So for wiring, I worked with the video in below as a reference.
If you don't mind, can you explain me how to wiring?
I connected simply, each original + line to + connector of subwoofer, each original - line to - connector of subwoofer.
Or do I have to follow below wiring?
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! 1740852548932-17
Cucurú
DFW Tx.
It's so strange.
Is your sub a dual voice coil? The sub in the diagram is a dual voice coil.
Honor
Korea
S650
My new subwoofer is PIONEER TS-A250D4 and As I know, this subwoofer is dual voice coil.
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! 1740875202344-01
In below video prepared by 'Tuxon Speed", PIONEER TS-A250D4 was used, I could not find how to wiring.
In other below video, also PIONEER TS-A250D4 was used, it seems that new wiring is same with
OEM wiring.
Below diagram is my current wiring.
S650 Mustang $79 Subwoofer Upgrade (Pioneer TS-A250D4 10" Sub) - IT SOUNDS GREAT! KakaoTalk_20250302_094519669
Is it correct? or please let me know correct one.
This issue is killing me.
Cucurú
DFW Tx.
OEM wiring.
That may give it a 2 ohm load and may blow amp. I wired 3 JL 10W6 with 6 ohm voice coils to make a 4 ohm load to a bridged 1000 watt amp. I would consult someone at a car stereo. What you want is a 4 ohm load. Your present speaker, I believe, may be 4 ohm each voice coil.
Honor
Korea
S650
Thank you for your reply.
As I told, I wanna know that only wiring between 2 connectors of subwoofer and OEM wire.
If OEM wiring(each pair line to each pair connector) can be applied to new subwoofer, TS-A250D4, my audio system is malfucion.
Below diagram is my current one.
But if OEM wiring can not be applied to new subwoofer, I have to know new wiring method.
(I could not find the case of 2 pair lines to 2 pair connecors, only the case of 1 pair line to 2 pair connectors was found.)
If you know, new wiring method, please help me.
Cucurú
DFW Tx.
I found a site on How to wire a dual voice coil speaker. The guy is a specialist. Sound certified.com
Honor
Korea
S650
Thank you for your kind reply. However I could not find 2 pair line to 2 connectors like mustang case.
Cucurú
DFW Tx.
It's been many years since I dealt with dual voice coil. I used a single VC 18" with a Fosgate amp in my Mustang. I did the work fitting the sub into a round box that goes into the wheel well. Put the amp under my seat. Pounds real nice. The rest of my family has the B&Os. The guy on the site seems to have great experience.
