- Joined
- Sep 22, 2022
- Threads
- 69
- Messages
- 2,181
- Reaction score
- 3,215
- Location
- Cave Creek, Arizona
- Website
- roketgamer.dev
- Vehicle(s)
- 2024 Ford Mustang Dark Horse
- Thread starter
- #1
BCMC/BJB (Body Control Module C/Battery Junction Box)
Engine bay, cover has 2 clips that press in and 2 bumps you bend the cover over, then lift the cover up
BJB Normal
GTD Fuses
BJB High Current
This is the same on the GTD
BCM (Body Control Module)
Passenger footwell, cover back snaps open, then cover lifts up and off
GTD BCM Fuses
Rear Battery Junction Box (RJB)
GTD Only
Somewhere in the technical panel, probably
RJB High Current
GTD Only
Somewhere attached to the RJB, probably
Rear Power Distributation Unit (PDU)
GTD Only
Somewhere in the rear of the vehicle, probably
Auxiliary Relay Box
GTD Only
Location Unknown
BJB Normal
Fuse Location | Amp Rating | Usage | Fuse Type |
BJB - 1 | 40A | BCM | Single |
BJB - 2 | 30A | Unused | Single |
BJB - 3 | 30A | BCM | Single |
BJB - 4 | 40A | Fuel Pump Control Module | Single |
BJB - 5 | 5A | Unused | Single |
BJB - 6 | 15A | PCM | Single |
BJB - 7 | 30A | EVAP Vent Valve, Oxygen Sensors, VCT Solenoids | Single |
BJB - 8 | 15A | Cooling Fan Relay, Variable Oil Pump, Turbo Bypass Valve, Active Grille Shutter, A/C Compressor Control Solenoid, Engine Coolant Bypass Valve, Differential Fluid Pump, Active Exhaust Motors | Single |
BJB - 9 | 20A | Ignition Coils, Ignition Transformer Capacitor | Single |
BJB - 11 | 30A | Starter Motor | Single |
BJB - 13 | 40A | Blower Motor Control Module | Single |
BJB - 14 | 5A | Unused | Single |
BJB - 16 | 10A | Luggage Compartment Lid Latch | Single |
BJB - 17 | 5A | Unused | Single |
BJB - 21 | 10A | Unused | Single |
BJB - 22 | 5A | Unused | Single |
BJB - 23 | 5A | ABS Module | Single |
BJB - 24 | 10A | PCM, PSCM | Single |
BJB - 25 | 10A | Unused | Single |
BJB - 26 | 10A | Unused | Single |
BJB - 27 | 5A | Unused | Single |
BJB - 28 | 40A | ABS Module | Single |
BJB - 29 | 60A | ABS Module | Single |
BJB - 30 | 30A | Front Seat Control Right, DSM | Single |
BJB - 31 | 30A | Front Seat Control Left, DSM | Single |
BJB - 32 | 20A | Front Power Outlet Socket | Single |
BJB - 33 | 20A | Aux. Power Point | Single |
BJB - 34 | 20A | Unused | Single |
BJB - 37 | 20A | Convertible Top Motor 1 | Single |
BJB - 38 | 30A | HVAC Control Module, DSM | Single |
BJB - 39 | 20A | Unused | Single |
BJB - 41 | 20A | Convertible Top Motor 2 | Single |
BJB - 44 | 15A | Unused | Single |
BJB - 50 | 40A | Heated Rear Window, Antenna Wave Trap | Single |
BJB - 51 | 10A | Exterior Mirrors | Single |
BJB - 61 | 30A | Unused | Single |
BJB - 62 | 10A | Unused | Single |
BJB - 67 | 20A | 10R80 Transmission | Single |
BJB - 68 | 20A | Steering Column Lock Module | Single |
BJB - 69 | 30A | Windshield Wiper Motor | Single |
BJB - 71 | 20A | Unused | Single |
BJB - 83 | 15A | Unused | Single |
BJB - 84A | 30A | Unused | Single |
BJB - 84B | 30A | Unused | Single |
BJB - 85 | 40A | Unused | Single |
BJB - 87 | 15A | Unused | Single |
BJB - 93 | 10A | Unused | Single |
BJB - 95 | 10A | Unused | Single |
BJB - 96 | 10A | Unused | Single |
BJB - 97 | 20A | Unused | Single |
BJB - 99 | 10A | Unused | Single |
BJB - 100 | 15A | Left Headlight | Single |
BJB - 101 | 15A | Right Headlight | Single |
BJB - 120 | 15A | Fuel Injectors, PCM | Single |
BJB - 124 | 5A | Rain Sensor | Single |
BJB - 125 | 5A | Unused | Single |
BJB - 130 | 20A | Differential Fluid Pump | Single |
BJB - 132 | 15A | Unused | Single |
BJB - 137 | 10A | IPMA | Single |
BJB - 139 | 5A | USB Charge Port | Single |
BJB - 140 | 5A | Unused | Single |
BJB - 146 | 5A | Unused | Single |
BJB - 148 | 5A | Left Taillight | Single |
BJB - 149 | 5A | Right Taillight | Single |
BJB - 158 | 20A | 10R80 Transmission | Single |
BJB - 159 | 5A | Unused | Single |
BJB - 160 | 10A | Remote Data Link Connector | Single |
BJB - 169 | 10A | Unused | Single |
BJB - 170 | 10A | Unused | Single |
BJB - 171 | 10A | Unused | Single |
BJB - 181 | 5A | HCM | Single |
BJB - 182 | 30A | BCM | Single |
BJB - 183 | 30A | Unused | Single |
BJB - 184 | 7.5A | WACM | Single |
GTD Fuses
BJB - 4 | 15A | Rear Battery Junction Box | Single |
BJB - 7 | 30A | EVAP Vent Valve, Oxygen Sensors, VCT Solenoids, Secondary Air Switching Valves | Single |
BJB - 8 | 15A | Cooling Fan Relay, A/C Compressor Control Solenoid, Active Exhaust Motors, Secondary Air Pumps Module | Single |
BJB - 16 | 10A | Technical Panel Latch | Single |
BJB - 21 | 10A | Rear Battery Junction Box | Single |
BJB - 23 | 10A | ABS Module | Single |
BJB - 30 | 30A | Front Seat Control Left, DSM | Single |
BJB - 31 | 30A | Front Seat Control Right | Single |
BJB - 37 | 20A | Unused | Single |
BJB - 39 | 7.5A | Front Damper Control Modules | Single |
BJB - 41 | ----- | Unused | Single |
BJB - 50 | 40A | Antenna Wave Trap | Single |
BJB - 51 | 10A | Unused | Single |
BJB - 67 | ----- | Unused | Single |
BJB - 68 | 20A | Unused | Single |
BJB - 83 | 15A | Charge Air Cooler Coolant Pump | Single |
BJB - 130 | ----- | Unused | Single |
BJB - 148 | 10A | Left Taillight | Single |
BJB - 149 | 10A | Right Taillight | Single |
BJB - 158 | 20A | Unused | Single |
BJB High Current
BJBHC - 1 | 275A | Alternator | Solid |
BJBHC - 2 | 60A | BCM | Solid |
BJBHC - 4 | 60A | Power Steering | Solid |
BJBHC - 9 | 60A | Cooling Fan | Solid |
BJBHC - 13 | 60A | Power Steering | Solid |
BCM - 01 | ----- | Unused | Single |
BCM - 02 | 10A | Windows and Locks | Single |
BCM - 03 | 7.5A | Unused | Single |
BCM - 04 | 20A | DSP Module | Single |
BCM - 05 | ----- | Unused | Single |
BCM - 06 | 10A | Security Horn Relay | Double |
BCM - 07 | 10A | BCMB (Early Production) | Double |
BCM - 08 | 5A | TCU Module | Double |
BCM - 09 | 5A | Intrusion/Inclination Sensor, Park Brake Switch, ETC Transponder | Double |
BCM - 10 | ----- | Unused | Double |
BCM - 11 | ----- | Unused | Double |
BCM - 12 | 7.5A | HVAC Control Module | Double |
BCM - 13 | 7.5A | IPC Display, SCCM | Double |
BCM - 14 | 15A | Unused | Double |
BCM - 15 | 15A | APIM | Double |
BCM - 16 | ----- | Unused | Single |
BCM - 17 | 7.5A | Unused | Double |
BCM - 18 | 7.5A | Unused | Double |
BCM - 19 | 5A | Headlamp Control | Double |
BCM - 20 | 5A | Start/Stop Button | Double |
BCM - 21 | 5A | ETC Transponder | Double |
BCM - 22 | 5A | VDM | Double |
BCM - 23 | 30A | PDM, Regulator Motors | Single |
BCM - 24 | 30A | VDM | Single |
BCM - 25 | 20A | DSP Module | Single |
BCM - 26 | 30A | PDM, Right Regulator Motor | Single |
BCM - 27 | 30A | Left-Rear Window Motor | Single |
BCM - 28 | 30A | Right-Rear Window Motor | Single |
BCM - 29 | 15A | IPC | Single |
BCM - 30 | 5A | Unused | Single |
BCM - 31 | 10A | RTM, Audio Control Panel, GWM, IPC Display | Single |
BCM - 32 | 20A | ACM, APIM | Single |
BCM - 33 | ----- | Unused | Single |
BCM - 34 | 30A | Run/Start Relay | Single |
BCM - 35 | 5A | BCMB (Early Production) | Single |
BCM - 36 | 15A | Unused | Single |
BCM - 37 | 20A | SCCM, Auto-Dimming Rear View Mirror | Single |
GTD BCM Fuses
BCM - 02 | 10A | Windows Regulator Motors, Window Control Switches | Single |
BCM - 07 | 10A | BCMB | Double |
BCM - 09 | 5A | Intrusion/Inclination Sensor | Double |
BCM - 20 | 5A | Start/Stop Button, Gear Shift Module | Double |
BCM - 21 | 5A | Unused | Double |
BCM - 22 | 5A | Unused | Double |
BCM - 23 | 30A | DDM, Left Regulator Motor | Single |
BCM - 24 | 30A | Unused | Single |
BCM - 27 | 30A | Unused | Single |
BCM - 28 | 30A | Unused | Single |
BCM - 32 | 20A | ACM | Single |
BCM - 35 | 5A | BCMB | Single |
GTD Only
RJB - 01 | 10A | Rear Damper Control Modules | Unknown |
RJB - 02 | 10A | VDM | Unknown |
RJB - 03 | ----- | Unused | Unknown |
RJB - 04 | ----- | Unused | Unknown |
RJB - 05 | 15A | Transaxle Fan Control Module | Unknown |
RJB - 06 | 10A | Transmission Control Module | Unknown |
RJB - 07 | 15A | VDM | Unknown |
RJB - 08 | ----- | Unused | Unknown |
RJB High Current
GTD Only
RJBHC - 01 | 125A | Hydraulic Pump | Solid |
GTD Only
PDU - 01 | 30A | R1 Auxiliary PDU Relay | Unknown |
PDU - 02 | 40A | Rear Battery Junction Box | Unknown |
PDU - 03 | 30A | R3 Auziliary PDU Relay | Unknown |
PDU - 04 | 30A | Run/Start Relay 2 | Unknown |
Auxiliary Relay Box
GTD Only
Location Unknown
ARB - 01 | 50A | Durite Relay 1 | Unknown |
ARB - 02 | 50A | Durite Relay 2 | Unknown |
