a comprehensive list of all the fuses as of June 11th, 2025
some important notes:
1. there are no engine running switched fuses anywhere
2. all relays except the one to power the cooling fan are non-serviceable and built into one of the fuse boxes
BCMC/BJB (Body Control Module C/Battery Junction Box)
Engine bay, cover has 2 clips that press in and 2 bumps you bend the cover over, then lift the cover up
BJB Normal
S650 Mustang S650 Mustang Fuse Box Diagrams 1709746571624
Fuse LocationAmp RatingUsageFuse TypeHot When
BJB - 140ABCMSingleAll Times
BJB - 230AUnusedSingleNever
BJB - 330ABCMSingleAll Times
BJB - 440AFuel Pump Control ModuleSingleAll Times (Fuel Pump Relay Switched)
BJB - 55AUnusedSingleNever
BJB - 615APCMSingleAll Times (PCM Power Relay Switched)
BJB - 730AEVAP Vent Valve, Oxygen Sensors, VCT SolenoidsSingleAll Times (PCM Power Relay Switched)
BJB - 815ACooling Fan Relay, Variable Oil Pump, Turbo Bypass Valve, Active Grille Shutter, A/C Compressor Control Solenoid, Engine Coolant Bypass Valve, Differential Fluid Pump, Active Exhaust MotorsSingleAccessory or Running
BJB - 920AIgnition Coils, Ignition Transformer CapacitorSingleAccessory or Running
BJB - 1130AStarter MotorSingleAll Times (Starter Relay Switched)
BJB - 1340ABlower Motor Control ModuleSingleAll Times (Blower Motor Relay Switched)
BJB - 145AUnusedSingleNever
BJB - 1610ALuggage Compartment Lid LatchSingleAll Times (Decklid Release Relay Switched)
BJB - 175AUnusedSingleNever
BJB - 2110AUnusedSingleAccessory or Running
BJB - 225AUnusedSingleNever
BJB - 235AABS ModuleSingleAccessory or Running
BJB - 2410APCM, PSCMSingleAccessory or Running
BJB - 2510AUnusedSingleNever
BJB - 2610AUnusedSingleNever
BJB - 275AUnusedSingleNever
BJB - 2840AABS ModuleSingleAll Times
BJB - 2960AABS ModuleSingleAll Times
BJB - 3030AFront Seat Control Right, DSMSingleAll Times
BJB - 3130AFront Seat Control Left, DSMSingleAll Times
BJB - 3220AFront Power Outlet SocketSingleAll Times (Latching Power Point 1 Relay Switched)
BJB - 3320AAux Power PointSingleAll Times (Latching Power Point 1 Relay Switched)
BJB - 3420AUnusedSingleAll Times (Latching Power Point 2 Relay Switched)
BJB - 3720AConvertible Top Motor 1SingleAll Times
BJB - 3830AHVAC Control Module, DSMSingleAll Times
BJB - 3920AUnusedSingleNever
BJB - 4120AConvertible Top Motor 2SingleAll Times
BJB - 4415AUnusedSingleNever
BJB - 5040AHeated Rear Window, Antenna Wave TrapSingleAll Times (Rear Window Defrost Relay Switched)
BJB - 5110AExterior MirrorsSingleAll Times (Rear Window Defrost Relay Switched)
BJB - 6130AUnusedSingleNever
BJB - 6210AUnusedSingleNever
BJB - 6720A10R80 Transmission (Late Production RHD)SingleAll Times (10R Trans Oil Pump Relay Switched)
BJB - 6820ASteering Column Lock ModuleSingleAll Times (Steering Column Lock Relay Switched)
BJB - 6930AWindshield Wiper MotorSingleAll Times (Wiper Motor Relay Switched)
BJB - 7120AUnusedSingleAll Times (Wiper Motor Relay Switched)
BJB - 8315AUnused (would normally be Charge Air Cooler Pump)SingleAll Times (PCM Power and CAC Pump Double Relay Switched)
BJB - 84A30AUnusedSingleNever
BJB - 84B30AUnusedSingleNever
BJB - 8540AUnused (would normally be eLSD)SingleAll Times (PCM Power and eLSD Double Relay Switched)
BJB - 8715AUnusedSingleNever
BJB - 9310AUnusedSingleNever
BJB - 9510AUnusedSingleNever
BJB - 9610AUnusedSingleNever
BJB - 9720AUnusedSingleNever
BJB - 9910AUnusedSingleNever
BJB - 10015ALeft HeadlightSingleAll Times (Left Headlight Relay Switched)
BJB - 10115ARight HeadlightSingleAll Times (Right Headlight Relay Switched)
BJB - 12015AFuel Injectors, PCMSingleAll Times (Fuel Pump Relay Switched)
BJB - 1245ARain SensorSingleAll Times (Wiper Motor Relay Switched)
BJB - 1255AUnusedSingleAll Times (Latching Power Point 2 Relay Switched)
BJB - 13020ADifferential Fluid PumpSingleAll Times (Differential Fluid Pump Relay Switched)
BJB - 13215AUnusedSingleNever
BJB - 13710AIPMASingleAll Times (ADAS Relay Switched)
BJB - 1395AUSB Charge PortSingleAll Times (Latching Power Point 2 Relay Switched)
BJB - 1405AUnusedSingleAll Times (Latching Power Point 2 Relay Switched)
BJB - 1465AUnusedSingleNever
BJB - 1485ALeft TaillightSingleAll Times (Aux Battery Saver Relay Switched)
BJB - 1495ARight TaillightSingleAll Times (Aux Battery Saver Relay Switched)
BJB - 15820A10R80 TransmissionSingleAccessory or Running
BJB - 1595AUnusedSingleNever
BJB - 16010ARemote Data Link ConnectorSingleAll Times
BJB - 16910AUnusedSingleNever
BJB - 17010AUnusedSingleNever
BJB - 17110AUnusedSingleNever
BJB - 1815AHCMSingleAll Times (Left Headlight Relay Switched)
BJB - 18230ABCMSingleAll Times
BJB - 18330AUnusedSingleNever
BJB - 1847.5AWACMSingleAll Times
GTD Fuses
BJB - 415ARear Battery Junction BoxSingleAll Times (Fuel Pump Relay Switched)
BJB - 730AEVAP Vent Valve, Oxygen Sensors, VCT Solenoids, Secondary Air Switching ValvesSingleAll Times (PCM Power Relay Switched)
BJB - 815ACooling Fan Relay, A/C Compressor Control Solenoid, Active Exhaust Motors, Secondary Air Pumps ModuleSingleAccessory or Running
BJB - 1610ATechnical Panel LatchSingleAll Times (Decklid Release Relay Switched)
BJB - 2110ARear Battery Junction BoxSingleAccessory or Running
BJB - 2310AABS ModuleSingleAccessory or Running
BJB - 3030AFront Seat Control Left, DSMSingleAll Times
BJB - 3130AFront Seat Control RightSingleAll Times
BJB - 3320AAux. Power PointSingleAll Times (Latching Power Point 1 Relay Switched)
BJB - 3720AUnusedSingleNever
BJB - 397.5AFront Damper Control ModulesSingleAccessory or Running
BJB - 41-----UnusedSingleNever
BJB - 5040AAntenna Wave TrapSingleAll Times (Rear Window Defrost Relay Switched)
BJB - 5110AUnusedSingleAll Times (Rear Window Defrost Relay Switched)
BJB - 67-----UnusedSingleNever
BJB - 6820AUnusedSingleAll Times (Steering Column Lock Relay Switched)
BJB - 6930AWindshield Wiper MotorSingleAll Times (Windshield Wiper Motor Relay Switched)
BJB - 7120AUnusedSingleAll Times (Windshield Wiper Motor Relay Switched)
BJB - 8315ACharge Air Cooler Coolant PumpSingleAll Times (PCM Power and CAC Pump Double Relay Switched)
BJB - 8540AUnusedSingleAll Times (PCM Power and eLSD Double Relay Switched)
BJB - 1245ARain SensorSingleAll Times (Windshield Wiper Motor Relay Switched)
BJB - 130-----UnusedSingleNever
BJB - 14810ALeft TaillightSingleAll Times (Aux Battery Saver Relay Switched)
BJB - 14910ARight TaillightSingleAll Times (Auz Battery Saver Relay Switched)
BJB - 15820AUnusedSingleNever
BJB High Current
S650 Mustang S650 Mustang Fuse Box Diagrams 1709744866777
This is the same on the GTD
BJBHC - 1275AAlternatorSolidAll Times
BJBHC - 260ABCMSolidAll Times
BJBHC - 460APower SteeringSolidAll Times
BJBHC - 960ACooling FanSolidAll Times
BJBHC - 1360APower SteeringSolidAll Times
BCM (Body Control Module)
Passenger footwell, cover back snaps open, then cover lifts up and off
S650 Mustang S650 Mustang Fuse Box Diagrams 1709744425314
BCM - 01-----UnusedSingleNever
BCM - 0210AWindows and LocksSingleAll Times (Accessory Delay Relay Switched)
BCM - 037.5AUnusedSingleAll Times
BCM - 0420ADSP ModuleSingleAll Times
BCM - 05-----UnusedSingleNever
BCM - 0610ASecurity Horn RelayDoubleAll Times
BCM - 0710ABCMB (Early Production)DoubleAll Times
BCM - 085ATCU ModuleDoubleAll Times
BCM - 095AIntrusion/Inclination Sensor, Park Brake Switch, ETC TransponderDoubleAll Times
BCM - 10-----UnusedDoubleNever
BCM - 11-----UnusedDoubleNever
BCM - 127.5AHVAC Control ModuleDoubleAll Times
BCM - 137.5AIPC Display, SCCMDoubleAll Times
BCM - 1415AUnusedDoubleAll Times
BCM - 1515AAPIMDoubleAll Times
BCM - 16-----UnusedSingleNever
BCM - 177.5AUnusedDoubleAccessory or Running
BCM - 187.5AUnusedDoubleAccessory or Running
BCM - 195AHeadlamp ControlDoubleAll Times
BCM - 205AStart/Stop ButtonDoubleAll Times
BCM - 215AETC TransponderDoubleAccessory or Running
BCM - 225AVDMDoubleAccessory or Running
BCM - 2330APDM, Regulator MotorsSingleAll Times
BCM - 2430AVDMSingleAll Times
BCM - 2520ADSP ModuleSingleAll Times
BCM - 2630APDM, Right Regulator MotorSingleAll Times
BCM - 2730ALeft-Rear Window MotorSingleAll Times
BCM - 2830ARight-Rear Window MotorSingleAll Times
BCM - 2915AIPCSingleAll Times
BCM - 305AUnusedSingleNever
BCM - 3110ARTM, Audio Control Panel, GWM, IPC DisplaySingleAll Times
BCM - 3220AACM, APIMSingleAll Times
BCM - 33-----UnusedSingleNever
BCM - 3430ARun/Start RelaySingleAll Times
BCM - 355ABCMB (Early Production)SingleAccessory or Running
BCM - 3615AUnusedSingleAccessory or Running
BCM - 3720ASCCM, Auto-Dimming Rear View MirrorSingleAccessory or Running
GTD BCM Fuses
BCM - 0210AWindows Regulator Motors, Window Control SwitchesSingleAll Times (Accessory Delay Relay Switched)
BCM - 0710ABCMBDoubleAll Times
BCM - 095AIntrusion/Inclination SensorDoubleAll Times
BCM - 187.5AUnusedDoubleNever
BCM - 205AStart/Stop Button, Gear Shift ModuleDoubleAll Times
BCM - 215AUnusedDoubleNever
BCM - 225AUnusedDoubleNever
BCM - 2330ADDM, Left Regulator MotorSingleAll Times
BCM - 2430AUnusedSingleNever
BCM - 2730AUnusedSingleNever
BCM - 2830AUnusedSingleNever
BCM - 3220AACMSingleAll Times
BCM - 3430ARun/Start RelaySingleNever
Rear Battery Junction Box (RJB)
GTD Only
Somewhere in the technical panel, probably
S650 Mustang S650 Mustang Fuse Box Diagrams 1742516885325-mu
RJB - 0110ARear Damper Control ModulesUnknownAccessory or Running
RJB - 0210AVDMUnknownAccessory or Running
RJB - 03-----UnusedUnknownNever
RJB - 04-----UnusedUnknownNever
RJB - 0515ATransaxle Fan Control ModuleUnknownAll Times
RJB - 0610ATransmission Control ModuleUnknownAll Times
RJB - 0715AVDMUnknownAll Times
RJB - 08-----UnusedUnknownNever
RJB High Current
GTD Only
Somewhere attached to the RJB, probably
S650 Mustang S650 Mustang Fuse Box Diagrams 1742517163686-u9
RJBHC - 01125AHydraulic PumpSolidAll Times
Rear Power Distributation Unit (PDU)
GTD Only
Somewhere in the rear of the vehicle, probably
S650 Mustang S650 Mustang Fuse Box Diagrams 1742517342838-7m
PDU - 0130AR1 Auxiliary PDU RelayUnknownAll Times
PDU - 0240ARear Battery Junction BoxUnknownAll Times
PDU - 0330AR3 Auxiliary PDU RelayUnknownAll Times
PDU - 0430ARun/Start Relay 2UnknownAll Times
Auxiliary Relay Box
GTD Only
Location Unknown
S650 Mustang S650 Mustang Fuse Box Diagrams 1742517541916-66
ARB - 0150ADurite Relay 1UnknownAll Times
ARB - 0250ADurite Relay 2UnknownAll Times
DCBuckeye
I'm a bit of a dullard on this. Which fuse in the passenger box would folks recommend tapping for the on/off of an audio amp? Something that's "on" only when the car is on. 12? 31?
Bandiz
Lithuania
S650
and I would like to share fuse panel locations for S650 if someone will need it..
Engine bay fuse panel
S650 Mustang S650 Mustang Fuse Box Diagrams ang-2023-2025-engine-compartment-fuse-box-location
Interior fuse panel
S650 Mustang S650 Mustang Fuse Box Diagrams -2023-2025-Passenger-Compartment-Fuse-Box-Location
I hope that will be useful info
8915GT
The BCM fuse list does not match what in my GT or the owners manual, where did you get this info or is for different model?
based on your vehicle listed in your profile, you're trying to compare your 2015 Mustang BCM fuses to a 2024 Mustang BCM.
8915GT
The main post has been updated to include the fuse layouts for the GTD, including its unique 4 additional fuse boxes
I tried to compare the fuse list on this thread to my fuse list, but it's too much work to check 1 by 1 if everything matches. But all the random fuses I checked matched with the ones on this thread.
Can you give me an example of things that are different in your manual so I can see if it's different for me too?
5.0ALM
Brisbane, Australia
Thanks to everyone who has contributed information.
Here's my contribution.
Information collated as PDFs, so they can be saved and referred to offline.
I'm old skool, so I like to have hard copy I can work with by the car.
S650 Mustang S650 Mustang Fuse Box Diagrams _DSC2690_1200
I was sniffing around months ago for an IGN feed for my front camera project.
S650 Mustang S650 Mustang Fuse Box Diagrams _DSC2705_1200
The only physical differences I found between the information and actual BJB fuses was the * SHOCK HORROR * absence of the 10R80 related fuses BJB-67 and BJB-158. As per my sig, I have a RHD 6-Sp manual.
Didn't check the BCM fusebox... our RHD accelerator pedal makes that difficult, and I didn't need to do it at the time.
Sorry, fuse tables are pre-GTD update and GTD not included.
Note two versions, A4 (most of World) and US Letter versions.
Hope this helps somebody.
dcheatham01
arkansas
2024 mustang GT
Which fuse did you end up using for a switched source?
updated this once more. fixed some minor errors, like one fuse being specifically for RHD late production 10R80 vehicles. also added info on when each fuse is hot, and if it depends on a relay or relays, which one(s) for it to go hot.
@5.0ALM in case you want to update your guides
