Schwerin
Philly
2019 Mustang BULLITT
thePill is curious as well because he specifically was told and reported on M7G a while ago that the 5.4 Coyote was supposed to be a 5.5 liter engine. Ford would attempt to push the maximum displacement in GT3.
In my opinion, Ford would GREATLY benefit if they could develop another Flat-Plane Crank BUT, a 5.5 liter FPC would be INSANE and probably hard to do.
thePill was under the impression that the 5.5 (or 5.450cc) would be the basis for the GT500’s new engine. He added that MAYBE we would see another FPC attempt at maybe a slightly smaller displacement while utilizing the 5.4’s internals.
A GT350 with a Flat-Plane 5.0 OR, a 289. The continued development on the 5.0 tells us that Ford is still invested.
The Corvette Z06 has a 5.5l FPC
because_murica
United States
2013 Camaro SS-1LE
The one thing that everyone has been overlooking and ford has been completely silent about is that the new pony will be equipped with auto start/stop. Lets hope that we wont have to turn it off every time we turn the engine on like the other models. I dont think that even grandma wants that on her mustang. 😒
Unclear if on the manual as well (even though Porsche does have it on their manual 911s). In any event, super easy to permanently disable via Forscan.
thePill
Camaro5's Most Wanted
Pittsburgh
S550
The issue again is getting air into such an engine while utilizing its powerband somewhere over 7500rpm.
The Corvette was forced to move into a mid-engine configuration to try and take advantage of the inert atmosphere towards the rear of the vehicle. Similar to “Cowl Induction” on a front engine car, the engine breathes oxygen from the slipstream.
However, any front engine vehicle is going to pull hot ambient air into the engine from extremely hot surface temperatures AND, airflow is blocked completely in traffic.
All things to consider… but if a FPC runs for Mayor of the GT350, thePill will vote for it.
MikeyV
Bay Area, CA
We've all see the auto start stop button. Makes sense that they kill the manual on the Ecoboost - and enable auto start stop. The Ecoboost is already designed for this.
The 5.0 has it too, I think - for the F150. But maybe they only enable it on Auto Equipped GTs.
Gogoggansgo
Midwest
2015 mustang GT
That turbo looks almost the same as the one on the updated 2.0 in the maverick interesting, honestly this might be the most interesting engine if makes a lot of power
zackmd1
1970 Mustang 429, Tesla Model 3
I am tempted to go with a S650 EB because of these upgrades.... I already have the V8 so the S650 would be my daily. 330hp with 30+mpg (highway) would be nice!
Hi-PO Stang
Minnesota
2014 Shelby GT500
I would have been happy with just a better flowing head for the 2.3 liter. Real curious to see torque and HP numbers on the new 2.3 liter.
zackmd1
Based off of what the chief engineer said in the podcast, I doubt we will see much of an HP increase over the current HO (330hp) model. Sounds like the upgrades were focused on making the engine more efficient for emissions. So maybe a bit more MPG and HP that would match the HO model. Power under the curve though will likely be drastically improved due to the electronically controlled turbo.
Alan Applegate
Roswell, NM
It is beyond me, why so many Mustang folks are anti Eco-Boost? I say this, because I have a 2024 Eco-Boost, and I like it! The last Mustang turbo I had was a 1979!
Just for the record, the 2024 2.3L is all new, as it only shares a few fasteners with the old one. The turbo is actually smaller (slightly) than the previous 2.3. Yes, it is only 5 HP more, but if you compare the HP and torque curves, you'll easily see the difference between them (old and new).
The Eco-Boost Premium is a bit faster to 60 than specs from Ford and some of the car mags. Of course they always drive models with the track package which has a 3:55 vs. 3:15, with the latter using a clutched limited slip differential not a TorSen. Fact is, if you use the drag setting, the difference between the two models is about .2 seconds, and even that is a bit generous.
When comparing the GT to the Eco-Boost in daily city traffic, most gear heads would choose the latter, especially so if you opted for the stick shift.
Speaking of transmissions. The 10R80 and its fuzzy logic programming is nearly perfect in the Eco-Boost, not so much (in my opinion) in the GT.
Not everything is perfect. I abhor the run-flat tires (Continentals in my case) for being terribly noisy, and not very sticky to boot especially in damp weather.
Enough said.
Bikeman315
Myrtle Beach, SC
2019 Mustang GT/CS
Enough said.
It is very simple. It is not a V8. As a proud past owner of a beautiful 2015 Ruby Red Ecoboost I’ve pretty much heard it all. You cannot argue with the “it’s not a Mustang if it doesn’t have a V8” crowd. Pointless. But there is one area in which they are right, sound. There is nothing like the sound of roaring Coyote. Honestly my 15’ was embarrassing. I’ve heard Ecoboost’s with the active exhaust. Better sure but never a Coyote. It is what it is.
But at the end of the day the Ecoboost is a great car. More than most people will ever need or want. So just enjoy and don’t bother with the haters.
One other thing. Please check your tires. I’ve never seen a Mustang equipped with run flats. Also Conti’s are known for their wet weather performance so check you air pressures. Something is not right.
