Bob77
florida
mustang gt, srt jeep,
Like the new 2025 GT premium but the whipple makes much more fun to drive. Definitely recommend!
MCS
SW Ontario
'24 DH Premium
Ford performance stage one kit. First pull after install 650 rear wheel hp
Not sure if the GT and the DH have the "same same" tune with regards to the kit?
I have the same kit and was able to get 707 rwhp on 94 with Comp Open Air boxes.
Did you guys use the same dyno one the same day?
gregrarnold
North Franklin, CT
‘24 Dark Horse Whippled, ‘24 F350 Platinum, ‘84 CJ-7, ‘19 Road Glide,
I ran mine on a mobile dyno today for fun after driving for a few hours. 3 pulls all within a few HP of each other.. I made my pulls in 5th gear (1:1) and said 671 hp & 545 ft/lbs.
For comparison my buddy ran his bone stock 2021 GT 500 right after me and made one more horsepower than I did with quite a bit more torque. 672 hp & 581 ft/lbs.
We both hit speed limiters before it hit rev limiter. My highest rpms were 7,040 rpm, like to think I could’ve squeezed a few more hp out if I didn’t have the Ford Performance Whipple tune with 150mph limiter and ran it up to redline.
S650 Mustang Whipple installed on 2025 Mustang GT IMG_4395
Bob77
Bob77
florida
Rev limiter is definitely a problem
beefcake
Gold Sponsor
Bethel
Awesome ! We love a Whippled S650 !
8LAKK8UNSHINE
Shelton, WA
2024 Mustang GT Premium Performance Pack 401A mag ride MT - Boosted
Thanks Beefcake. I would have a twin disk clutch for this thing BUT, when I ordered it, after waiting 3 months I cancelled the order. Would have been nice to install that clutch at the same time I had the headers put in. Maybe next time I order a clutch from SOMEONE, I can get that clutch in less than 3 months so it can go in when I build or swap the trans this winter.
8LAKK8UNSHINE
Shelton, WA
So far...not a damn thing! The best thing about this kit is that it drives OEM under around 4k RPMs. It's so quiet I can barely hear a little whistle and whoosh. Averaging close to 15 MPG. Honestly, the aluminum one piece driveshaft causes more NVH than the Whipple. This kit is awsome for daily and sleeper setups. My IATs are have gone up 5-10 degrees. I will end up with a dif cooler bc those temps are significantly higher. It's fine on the street, but around a road coarse it could be an issue after a couple 20 minute sessions.
Yes, that was my question, about the one piece driveshaft.
Will the factory driveshaft not live?
8LAKK8UNSHINE
Shelton, WA
The aluminum helps against parasiti drivetrain loss and if you launch the car at this power level, it will eventually preetzel. The aluminum is much stronger and carbon fiber, I hear is a little overkill and bad if it does explode. The aluminum has been good but I've noticced vibration at high RPMs. I tolerate it.
