What is this noise from oil cap? And why is there a "gap" in air/oil separator
MustangNoob
CA
Why is the rubber sealing visible in air/oil separator. The cap is tight. Driver's side is more visible.
And what is this noise coming from the oil cap?
Car has no issues
S650 Mustang What is this noise from oil cap? And why is there a "gap" in air/oil separator tempImageXoAJ6W
Deleted member 17846
Guest
It looks as if your oring might not be in the groove.
Did you just do an oil change. I had a somewhat similar noise after an oil change and it sounds like a solenoid. I was getting a slight bbq tick that would come n go till the car got up to temp.
Mine went away.
MustangNoob
MustangNoob
CA
Mine went away.
I have done 2 oil changes. The bbq tick appear after the first one. And that is normal.
However this noise is different and it seems is coming from the oil cap. And it does not seem to have any leaks....
@MustangNoob ....... respectfully, the Mustang BBQ tic is not normal as there is about a 50/50 chance of getting one - apparently for no known reason. That said, Ford has issued a TSB stating that the tic - also found on other Ford vehicles with the Coyote - will not result in future engine damage. When the tic first started being noticed Ford replaced a few Coyotes before halting the process. BTW IMO the best way to avoid the tic (which some friends have on their Mustangs and I find really annoying) is to use a FULL synthetic oil and to pre-fill your oil filter. I have had two oil changes since factory and have not been blessed with the tic yet.
MustangNoob
MustangNoob
CA
well 50% chance to have it or not seems to qualify as "normal" as not having it. If ford said that there is not a problem I wouldn't worry about. The sound might be annoying but that is fine. Will switch to fully synthetic oil next time and see if there is a difference. For now I worry about he noise that seems to be coming from the oil cap....any ideas?
24 vert
24 GT premium convertible PP
Take the oil cap off and see if the gasket underneath is missing. The gasket that goes on the oil cap may potentially fall out during a change. Not typical on something new, usually on older cars but there could be a manufacturing defect that caused the gasket to be loose and to be lost when the cap was previously removed. Take a look. Let us know.
Cheers,
24 Vert
The oil cap doesn't appear to be fully seated. It sounds like vacuum is escaping from that area as well. Between the lip of the oil cap and valve cover, there should be no gap. The two are normally flush with one another.
As to the oil separator, the O-ring and container are off by a bit. Seems OK. It doesn't appear to be weeping oil. IIRC, the Ford unit is taken apart to empty it. You can separate the two halves, inspect and possibly re-align. If it keeping a good seal, I'd leave as-is.
MustangNoob
MustangNoob
CA
@Skye @24 vert here are the pictures of the cap and the oil tube.
oring seems to be there but it does appear to have some wear (black spots).
Any possible issues fro the engine if there is indeed vacuum leak ?
S650 Mustang What is this noise from oil cap? And why is there a "gap" in air/oil separator tempImageh8cYLO
S650 Mustang What is this noise from oil cap? And why is there a "gap" in air/oil separator tempImage8CmN4M
S650 Mustang What is this noise from oil cap? And why is there a "gap" in air/oil separator tempImagerQP1Kh
From the latest photos and the original video, the filler cap is oriented correctly when down. But I cannot tell if it is sitting flush or not.
When the cap is in-place, is the flange of the cap flush with the valve cover? Or, is there a gap? It should be seated and flush.
As to the sounds, the PCV valve is sitting right there. I hear the sound of air passing by. Maybe I'm hearing that.
Often with a vacuum leak, the engine ingests more air than it should, the engine running leaner.
If you confirm the filler cap is seated flush, while the engine is running, I'd run your finger tip around the edge of the filler cap, then around the edge of the oil separator where you've seen that gasket concern. If you do not hear any change, like if you were checking for a leak, I take it as that's just the way it is. If you can change the tone or sound with your finger at some point, that's something to check.
Regarding the O-ring, it'd be a good practice to clean that, remove the deposits with a rag or something. I'd also run that within the seat of the valve cover, to ensure it's clean.
MustangNoob
MustangNoob
CA
Just came back from the dealership. They checked out and is the PCV valve (the brown part where the house from are AOS is connected. All normal. The guy suggested if I want to change that valve with a performance one front eh gt500. I was like nah if it normal not needed.
That's cool. Always good to have a cold pair of eyes look at a new concern.
Glad things worked out and there were no issues. :thumbsup:
24 vert
So in the end, did they say that was the PCV valve rattling / sucking air but it sounded like it was coming from the oil cap?
......fast forward to late 2025 early 2026 Mustang Coyote engines. Is anyone hearing reports of recent models having the Coyote Tic, BBQ Tic or Typewriter Tic Whatever you want to call it)......Just wondering if it has been solved (by Ford) and is now a thing of the past (having been solved) or have owners have just stopped reporting it?
D/\rK•650
2025 Mustang DarkHorse
That noise is the PCV. Mine same exact sound. The dealer checked mine and said as much. Its like a buzzing really fast clicking or vibrating type sound. I think its the metal ball in the pcv vibrating and buzzing from the vacuum pressures. Im not sure if that is the noise called the BBQ tick with these engines that everyone is referring to. It must be though unless there's a different noise there referring to. If im right and it's definitely the pcv it has nothing to do with oils or anything like that.
