TPX Laser Jammer DIY Install
Terminus
Alaska
25 400A 6-Speed Black/Black Nite Pony Performance Exhaust
Hello Fellow Pony Jockeys
Just for shits & giggles I installed a laser jammer. I installed a different brand on my fox body years ago.
I did this job without any cutting or drilling except for small slit in the center of firewall rubber plug.
TPX product
S650 Mustang TPX Laser Jammer DIY Install 20251012_193508
Wired to fuse box
S650 Mustang TPX Laser Jammer DIY Install 20251018_171826
CPU onto fender well via a fastener into an existing hole
S650 Mustang TPX Laser Jammer DIY Install 20251018_171802
Thru firewall
S650 Mustang TPX Laser Jammer DIY Install 20251018_171858
Control in the cockpit
S650 Mustang TPX Laser Jammer DIY Install 20251017_144020
S650 Mustang TPX Laser Jammer DIY Install 20251017_144034
Remove radiator cowling to access behind the grill
S650 Mustang TPX Laser Jammer DIY Install 20260512_144312(1)
S650 Mustang TPX Laser Jammer DIY Install 20260512_144853
I used steel band fasterners to attach CM transponders (jamming heads) to fins behind grill
S650 Mustang TPX Laser Jammer DIY Install 20260512_153825
If you look closely you can see the stainless steel fasteners attaching the 3 jamming heads behind the grill.
S650 Mustang TPX Laser Jammer DIY Install 20260512_184655
DarkHorsePremium
CA, Bay Area
Greetings,
Credit for the install. You are probably aware If the heads are obstructed in any way it reduces the overall effectiveness of the jamming capability. I understand there's a toss-up between the desire for stealth and not cutting. I think the TPX system claims to be waterproof. What is your feeling on that?
I have some additional questions. 🙂
Since you mounted the CPU in the fender well, did you install a USB extension for firmware updates?
How did you get through the firewall? I couldn't really tell by the picture.
Laser is very prevalent here in California. CHP uses it nearly as much as radar. Even smaller cities have guns now. It's hard to escape no matter where you drive here.
DarkHorsePremium
CA, Bay Area
good looking install, but unless you're being tagged from a fair ways in front, they're going to be rather ineffective. also you should know those shudders open and close, they don't stay still, so just hope they don't ruin the cables to the heads or close when you're being targeted
