speed limit signs in dash
D/\rK•650
2025 Mustang DarkHorse
Is there a way to disable the speed limit signs that show on my dash when driving? I've looked in the menus but I cant find a way to turn it off? I saw in the manual there is supposed to be a way to turn the feature off but I don't see it. Speed limit sign recognition is think it's called.
Frogdog1
Dixie
I can't answer your question but do remember, speed limits are for other people. 😁
I like the feature. We seem to have a different speed limit every couple of kms and I get curious as to how naughty I am being.
It's really accurate too, within a few metres of the sign.
D/\rK•650
D/\rK•650
I admit it's a neat feature. I just wondered if it can be disabled or turn it off. 🤔
A.alansari
Qatar
Mustang GT 2024 PP
you can in forscan
my car was disabled and I enabled it in forscan
D/\rK•650
D/\rK•650
Disable speed limit assist. It's under Driver Assistance in the settings menu.
Is your disabled? I've checked and mine is already set to off. Maybe there is a glitch in mine if yours is set to off and it's not on the display.
A.alansari
Qatar
Mustang GT 2024 PP
Where in Forscan did you adjust this? So you enabled the feature in Forscan? Im trying to disable it
these are my originals which was disabled
APIM:
7D0-05-01 0x0x xxxx xx--
7D0-09-02 xxxxx6xx x5--
7D0-09-04 xxxxxxxx 6x--
IPC:
720-03-01 x0xx xxxxxx--
720-09-01 xxxxxxxx1x--
IPMA:
706-01-01 xx0x xxxx xx--
706-02-01 2Axx xxxxxx--
keep in mind my car from Middle East so make sure before you change anything to read the attachment and see if the number you will change won't affect other things in you car
after finishing you need to reboot the modules in forscan as well
Yes, but I still have the speed limit indicator. I played with it this morning and it doesn't turn off. I guess it's only a forscan thing. Oh well. It's never bothered me.
samson
I think it's a neat feature. I do notice discrepancies from time to time. I run GoogleMaps almost constantly and it's interesting to see when the speed limit feature differs from one to the other. Nearly 100% of the time when it happens, the dash is the wrong one.
I'm sorry I don't know how to turn it off or if it's even possible.
DT-GT
I find the one in the dash that is read by the camera to be very accurate. Reads the signs for reduced speed in construction areas also.
