Software update today now Tire Pressure display shows no reading
JAM486HP
As title states, startup this am, update was available, let it download and install, all good. Now my tire pressure gauge is showing no data. In the car and on Ford Pass. Gauge is there, doesn't show any numbers. Checked in FORScan just to be sure it was enabled and it is. Anyone else experience this?
Any modifications?
Do numbers populate after you drive?
Any DTC’s showing in FORSCAN?
JAM486HP
JAM486HP
Any modifications?
No mods, no codes, just blanked out... going to put some miles on it and see if it resets
the new OTA update updated the ABS module, that may be why your tire pressures are blank. you should be able to drive a little bit and they will come back
Are you sure you still have tires? J/k although it reminds me of that old eddie murphy routine, talking cars and someone stole your battree
Which version?
And another Eddie Murphy after he takes it for a drive " I can see, I have legs" (tires)
JAM486HP
JAM486HP
Exactly what it was, thanks!
Reactions: Zig
37.5726028 / -85.1551411
F150, 2024 Mustang GT Vert
Was ur update, ABS-24.12.0? If so, see if any of ur buttons on the instrument panel, where Traction Control, Favorites, My Mustang, etc. are located are working. Mine are not after that particular update.
JAM486HP
JAM486HP
Was ur update, ABS-24.12.0? If so, see if any of ur buttons on the instrument panel (below center A/C vents, to the left of radio on/off button) where Traction Control, Favorites, My Mustang, etc. are located. Mine are not working after that particular update.
I will check to confirm the version number, though it was the ABS update. The My Mustang button was working, I will test the others after dinner and report back.
Mine do wonky things. Sometimes they are blank, sometimes they say the pressure is 9504 psi in all tires. Screws fall out. The world is an imperfect place.
