i have decided to go all-out on the extra buttons thing. i will be doing an overhead sunglasses holder delete as well so i can fit 5 of those double buttons from the F-series trucks.
i got the ones without the "ON" text. this means i will have 15 total buttons to do whatever i want with
You're gonna turn your Dark Horse into a Flying Horse.
No fooling, you gonna James Bond this thing with rockets and oil slick shooters?
you never know what you will need buttons for :)
i ordered the parts. Bronco headlamp switch and the five buttons should be here in a week. the F-150 headlamp switch is on backorder, so no ETA on that
i did some estimating and it turns out that 5 buttons is easy mode. i can fit up to 7, so i will be doing 7 instead, bringing the total button count to use how i want to 19
Change your name to Button Horse.
me when i forget what button does what and i didnt label them
S650 Mustang roket's Dark Horse - "Azureus" Project 1748381412598-tv
or when i do label them, but its with some incomprehensible icon
S650 Mustang roket's Dark Horse - "Azureus" Project 1748381571130-sb
making OEM-style icons for the buttons now. it looks like Ford usually constrains icons to a 10x10mm domain, and uses 0.5mm strokes, really only doing outlines. sometimes they fill things in too. here is my attempt at a trunk release icon. made using Inkscape.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748418151831-11
factory trunk release icon for comparison.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748418613815-22
going to be making as many icons that i can think i would need
6 of 7 buttons and 1 of 2 headlamp switches are here
S650 Mustang roket's Dark Horse - "Azureus" Project 1748545951387-sv
holding that many buttons feels weird, almost illegal. also, the upper-left button on the headlamp switch still pops the trunk
got the 7th button today. also good news on the cupholder front: i got the new lighting rings look like they are roughly the right shape! this will likely be good to model a cupholder for
S650 Mustang roket's Dark Horse - "Azureus" Project 1748634022279-il
Yamazuki
North Dakota, USA
I'll be interested to see where you end up with the cupholder!
I ordered all the parts to put the Corsair one in, but just wasn't happy with how it was going to fit.
BTW, if you were not already aware; the light rings can be removed from the Corsair cupholder as well and might provide some different options if the new ones you ordered don't work out.
so i decided to use some buttons that are going to be replaced on the headlamp switch anyways to test paint colors and removing the icons. my first attempt at removing the icons (or rather, the paint around them. the icons themselves are gaps in the paint to the translucent plastic) used my favorite material removal tool; dremel with an abrasive buffing wheel. i ended up putting too much pressure and now the button has the wavy texture of obsidian. attempt 2 used the little green cone stone thing at min speed with no pressure to break up the paint. then i used a mix of the abrasive buffing wheel at min speed with no pressure and 800 grit sandpaper. this worked so much better.
i then went to Home Depot and Lowe's to get some paint to test it out. i tried their closest matches; Tricorn Black from Lowe's, and Behr "Black" from Home Depot. here is the 10 minute drying results.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748662967145-j
left is Behr "Black", and right is Lowe's Tricorn Black. the Behr paint is spot on. i will check again tomorrow morning too. ignore the absolutely terrible paint distribution, i dont think house paint was designed to be applied with a tiny brush. if tomorrow morning Behr still looks good, then i will head back to Home Depot and get a spray can of it. if Tricorn Black manages to take the lead, then off to Sherwin-Williams it is
goodlettjr
Houston, TX
This is quite the endeavor to pull off a factory look. I am intrigued. Try some model paint for figurines. Not car models, but rather something like Dungeons and Dragons. There are quite a few game stores in the Phoenix area.
i went to Home Depot to buy some of that Baer Black in spray paint form, but satin was too glossy and matte was too dull. i also tried Sherwin-Williams but they had nothing to help me. i then went to Space Age Auto Paint 40 min away and was fully prepared to spend a pretty penny to have a custom mix made and put in a spray can (which is something they can do, and do every day). turns out, though, that there is already a color that someone made that is an exact match!
S650 Mustang roket's Dark Horse - "Azureus" Project 1748714919453-4r
both buttons are painted, and the surround is not. it is so incredibly similar that i am happy with it. the spray paint in question is "SEM 15243 Satin Black". it was rather expensive at just over $25 for a single can, but it ended up being worth it.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748715111770-pr
@goodlettjr no game stores required
