Removing the resonator and replacing it with an X or H pipe will sound great. The factory resonators dampen the sound quit a bit. As far as drone goes I wouldn't expect any from the resonator delete by itself. Only when you start adding headers and catback/axlebacks into the mix will that have the potential to cause drone depending on the setup.If the resonators are removed and an H pipe installed, would it sound better? What about drone?
Just ordered the steeda X-pipe from you guysRemoving the resonator and replacing it with an X or H pipe will sound great. The factory resonators dampen the sound quit a bit. As far as drone goes I wouldn't expect any from the resonator delete by itself. Only when you start adding headers and catback/axlebacks into the mix will that have the potential to cause drone depending on the setup.
Here's a link to the resonator deletes we offer for the S650.
https://www.lethalperformance.com/s...t/2024-mustang-gt/exhaust/resonator-deletes-1
Thank you for your business! We really appreciate it. Please make sure to do a product review of the X pipe once you install it on your car. Thanks again!!Just ordered the steeda X-pipe from you guys
Hey there.I'm interested in the Corsa double H pipe but it is pretty expensive. Is there a significant difference in tone compared to a single H pipe? I haven't really been able to find any comparison videos between a single H and double H on the same Mustang.
Sounds good, thanks!Hey there.
I've had both a traditional H midpipe and Corsa HH midpipe - there's a difference and it is noticeable, but it's not as drastic as when you go from stock to either of the midpipes. I enjoyed the Corsa HH most when it came to headers and high-flow cats.
Let us know if we can help out with either midpipe option!
