Rear glass defect or stain?
RafaelRM
Oviedo, Fl
Mustang GT Premium 2025
Hi! I bought my GT around 40 days ago. Today I notice these marks in the rear glass. It’s from outside because I can feel it with my finger nail. I tried to remove it but I couldn’t…. Not mentioning the scratch I found too…. Any of you guys know what is it? Do you think it worth to make a complain to replace the rear glass?
I’m afraid the new glass will be worst ( bad installation and water insulation) or leave the way it is…
S650 Mustang Rear glass defect or stain? IMG_6258
S650 Mustang Rear glass defect or stain? IMG_6259
rbeyer
2024 Mustang GT Base
I assume you bought this new? If so, absolutely, complain until it's right.
Paul's stable
Maple Ridge BC Canada
I bought it new.
Okay dumb question first have you tried cleaning the inside of the glass? It looks like (A) glass delamination or (B) window adessive that has seeped out and needs to be removed. Take it to the dealer they should fix it. Good luck with your car.
GrabberB
I had some odd looking streaks/smears/splotches on the inside of the back window that I didn't notice upon inspection during pickup (new). I looked over all the body panels and gaps and so on and somehow never paid any attention to the back glass,
When I first noticed them I had an oh crap moment. I hurriedly tried to clean the back window because I thought this might be permanent damage of some sort. The marks didn't budge. I dug in deeper with a hard elbow grease cleaning with success on the second attempt. The back glass is hard to reach and a pain to clean.
Speculation here. Not saying this is the case for you however a deep cleaning is worth a shot. By deep cleaning I mean hard elbow grease and Stoner's glass cleaner coupled with microfiber towel. No abrasives or harsh chemicals. I would never recommend cleaning vehicle glass with Windex or paper towels.
My theory is.... I'm guessing there is some sort of protective film applied to the glass that is removed at some point either pre or post installation on the assembly line. I surmise it's just as hard for assembly line workers to get whatever this is off and they let it slide. This is only a theory and I may very well be wrong IDK....
Alan Applegate
Roswell, NM
Dealers should indeed fix things like this, but don't be surprised if they won't.
I'm not a lawyer, so interpreting some of the fine print in the warranty document may be deficient. But as I recall, there are some limitations with respect fixing some paint blemishes and similar owner irritants. If they're not safety-related or perhaps gross (like a whole panel covered in orange peel), a dealer's ability to charge-back the manufacture is limited.
Many years ago, dealers used to do a better job of customer relations than they do now. Some dealers are still fantastic in this regard, but unfortunately they're becoming extinct! Seemingly, the profit is rule number one, and screw you the phrase of the times. Or is that... Up yours!
Doug Watson
When I bought my DH a year ago my rear window was a mess worse then yours. I used 3M compound cleaner and it cleaned up nicely. I have a scratch on my passenger window which Ford refuses to replace. Ford states because I waited a month after taking deliver they won't warranty it. I told them well I just found it but still no luck. Fords warranty sucks.
goodlettjr
Houston, TX
A dealer does not have the ability to charge back a manufacturer in any scenario. However almost all manufacturers have the ability to to do to the dealer. In fact the franchising dealers (99% of all dealers) are drafted straight out of a designated account by the manufacturer while the manufacturer provides the an “invoice” of the details (credit or debit). Just like an ACH draft or payment.
The way warranty works in a shop / body shop is two fold.
1. The dealer makes a subjective call. Repairs the issue and the manufacturer either approves it or denies it. Meaning the dealer either gets paid by the manufacturer, writes it off as a loss, or chases the customer down to pay.
2. There are areas of repair the require pre authorization. This comes for a few different reasons. It could be a dealer doesn’t have a “certified” tech to do the work and needs their hand held to make the right decisions. It could be that the dealers warranty % vs a peer group is high in the segment and they are on a probationary period. And last it could be subjective work that can be indentified wrong such as paint work.
The dealer never looks at your warranty that you signed or uses that to conduct warranty repairs. They use the manufacturers warranty manual of which we do not get a copy of and it changes periodically.’
Hope this helps your understanding of warranty.
OutofNowhere
2024 GT Premium; 2022 Edge Titanium
Did you have that back glass tinted?
If so, that scratch looks like a cut from a razor blade when they trimmed the tint to size. I had cuts all over my front glass that looked like that after having the windows tinted.
In theory, the tint is precut for all the glass except the front (so I've been told), but I had a scratch like that on my back glass as well. I really think was from the metal edge on a heat gun nozzle, since they lay the tint on the outside to heat it to get the curves semi-correct before putting it on the inside, but I never did get a solid answer about that part.
The tint shop eventually paid to replace my front and back glass because the damage was so bad.
See here for pics: https://www.mustang7g.com/forums/th...ated-now-turned-nightmare.162149/post-3301191
If you have had the windows tinted, you might ask the shop what chemicals they used during install too, since maybe that staining could be from some chemical used during application. You wouldn't think so, but I wouldn't have thought that they'd use a razor blade on the outside of my windows either, but here we are.
RafaelRM
Oviedo, Fl
I tinted but the shop used a precut machine to cut the exact size of the the glass. They showed me in the computer and I saw the machine cutting the tint. But I didn’t see they work on my glass.
OutofNowhere
The shop that damaged my glass also said they used a plotter to cut the tint for the back, yet that scratch was still there. Other professional tint installers that I've spoken with said that it could absolutely be from a heat gun.
I also talked at length with a couple of glass repair people and an auto glass installer, and they all said that kind of scratch can't be fixed like a chip can. You can't buff it out, but you also can't fill it with resin like you can with chips.
IFFV68
The Scratch should be an easy fix.
The Window will probably need to be replaced.
Please remember the Dealer will probably send your Mustang to a Glass Shop to replace it.
I don’t know of any Ford Dealers who does their own Glass Repair or Glass Replacements work?
Good Luck 🍀
GrabberB
Would have been nice if the OP mentioned he had the window tinted. Good catch by whoever ask that question. That changes everything.
