Need help for suspension setup!
sloww5ohh
2024 Yellow GT PP Magnaride
Hey guys
right now my car is pp magnaride
With
Bmr cradle lockout lvl 2
White line sway bars and end links
Bmr diff bushings
Looking to tighten up the rear end even more planning to get steeda drag springs.
Not trying to go crazy because I don’t want NVH but a few more pieces to help this Mustang launch hard. Especially when I add boost.
Thanks in advance
A.alansari
Qatar
Mustang GT 2024 PP
look for vertical links will help with the wheel hop
Atlanta
Ford Mustang Mach-E 2022
If you’re chasing rear stability without crazy NVH, the Steeda drag springs should play fine with your setup, as long as you pair them with good alignment and keep your bushings torqued at ride height. I had some clunks sorted out at an auto repair shop phoenix az after stiffening my rear, and they helped dial in the angles so the ride stayed smooth even with more aggressive parts.
steedazach
Valdosta
S650
To help with wheel hop, get the Steeda Stop the Hop kit. There are multiple different kits at different price points. The drag springs are really gonna help you out too. Anytime you do boosted applications and hard launches in the same sentence, you need to make sure you have the supporting mods to keep the car running smooth. Feel free to reach out and I can get you taken care of.
What have you done for wheels and tires? Lightweight skinny fronts with bias ply drag tires in the back will do a lot for 60 foot times.
