His most expensive rear wing is putting down between 500 and 1000 pounds of downforce at only 100 miles per hour. He recommends mounting it to the chassis, not a body panel or trunk lid.
It appears to be sucking up 30-60 horsepower at 100mph, too, though.
His splitters can come with custom tunnels increasing downforce, too.
And he tracks and competes with 2 (I think) S550 Mustangs (including a GT350).
38.9967° N, -84.6310° W
One way to compare would be to spend a lot of time at the track, keeping good records of your lap times and conditions.
Then install something like AJ Hartman's aero.
Then continue tracking your lap times and conditions.
Is there a consistent reduction in lap times in similar conditions?
Example: My favorite track was Mid Ohio in Lexington, OH., ran there about 3 times a year for 12 years. My best time was around 1:41, with stock OEM aero on my Roush mustang. Once I converted car to dedicated track car, adding AJ Hartman aero, Splitter, Diffuser, Canards and dropping some weight (car and driver), I began running times in 1:38+. Best time at Mid Ohio was a 1:36 during the NASA Championships in 2019, placing 8th in a field of 12. Damn Beemers were unbeatable. Anyway, yes, real track times and conditions proved AJ's Aero works and yes, I lost some straight line speed, dropped about 10 mph. Back straight at MO I used to run 145-150 mph, but with the new aero, I was running 135-140. To compensate I wanted more HP, but that would have dropped me into TT2 or TT1 class and the cars there were insanely fast.
AJ's daily track car is his 1999 mustang, running in American Iron Class. He picked up the S550 GT350 in 2020 and began transforming it into a track car, doing tons of aero testing, etc.
Interesting fact regarding downforce on F1 Cars. Never going to happen but if a long drivable corkscrew entry and exit were placed on a long upside down highway the following would be possible after 1 & 2 below were covered.
1. F1 Driver willing to display the downforce engineering and capabilities of an F1 car.
2. F1 team owner willing to provide F1 car.
An F1 car creates enough downforce to defy gravity and at speed be planted enough to drive upside down without dropping. To slow entering or exiting the corkscrews or not maintaining speed on the upside down stretch = gravity takes over and bad things happen. That's some serious downforce.
Just like a wing then. They can lift 1000's of kilos.
It'll be interesting to see what Vulcan Alpha come up with on Charoudin's DH. The 'Ring is a real downforce critical track apparently.
I also wonder about high downforce aero on street cars like GT3's and such, can't help fuel economy.
If anyone cares.
GrabberB
You mean, with today’s tech not too many reasons why the degree of banking in that curve can’t go inverted?
Very good Not sure how the above got mixed into below. Comment to above in another post.
It’s not downforce but momentum that permits movement otherwise once inverted downforce inherently becomes upforce. 🤣.
Very good point!
GrabberB
In theory, yes. Reality gets a yes too....... until the caution flag gets thrown and the competitors begin falling out of the race. :shock:
GrabberB
It’s the transfer to terra that becomes troublesome.
Very true.
What force allows an inverted F1 car to navigate an inverted road (at speed)?
A. Downforce
B. Upforce
C Inverted downforce
D. B or C above
Spectators 🙃🙃🙃🙃🙃🙃🙃🙃🙃🙃🙃🙃
Funny timing, but AJ Harman posted on Facebook today that he is working on the S650 this year, aero and magneride coilover conversion.
Very true.
A. Downforce
B. Upforce
D. B or C above
Driver
Funny timing, but AJ Harman posted on Facebook today that he is working on S650 this year, aero and magneride coilover conversion.
I almost thought you were gonna tell us about ‘Chrysler recalls nearly 75K SUVs over parts that could detach while driving’ (… the vehicles may have rear spoilers that were improperly aligned during installation…. Rear spoilers which detach from a vehicle may create road debris and increase the risk of a vehicle crash," the notice said)’
OX1
Jackson NJ
86 Capri 5.0 Turbo, 2017 Fusion Sport, 21 GT500
This was on my 21 GT500. Never did anything with it, but could be one way to measure before/after. Would need lots of data from a high speed straight. Take before/after averages from entire track day. Not sure how to log "height" sensors.
Decided next time I had lower tray off, I would gather some load, vs height, vs height sensor data.
The "experiment" setup.
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis 20240701_085445
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis 20240701_085500
Baseline height sensor voltages.
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis 20240701_090032
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis 20240701_090039
When I got to about 150 lbf, the lift towers started pulling inboard.
Was hoping weight on lift would be enough.
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis 20240701_090737
Happened to have a 10 or so foot, 2" square, 1/8 wall piece of tube kicking around, so cut it down to 100"
for a support between the towers. Re-baselined #'s, and they were the same. Used rubber pads on the end
of tube to protect lift finish.
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis 20240701_110830
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis 20240701_110837
I only went to about 323 lbf, was not comfortable going over that on forward end of "frame' (rad. support).
I don't think front aero creates more than that anyway, if we are in the 500 lbf range with large wing on back @ 180 MPH.
I blew right through 250, so only got data points @ approx 200 and 300 lbf.
Data........... Overall, you are looking at less than 1 inch of ride height change, and about .3 volt change on height sensors,
(@ around 300 ish lbf on the front end).
Spreadsheet link
http://luxjo.supermotors.net/2020 2...EST DATA PICS/GT500 FRONT DOWNFORCE DATA.xlsx
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis TEST%20DATAa
The only way to properly add a rear wing. When mine was installed, it had square tubing brackets mounted in trunk to frame, with mount slabs protruding thru drunk lid, where wing would be attached. PIA to open trunk, if needed, had to take wing off.
S650 Mustang Interesting Dark Horse High Performance Rear Wing Aero Analysis REAR WING 7
