Installing LED Side Markers...
FireArrow
Jacksonville NC
26 GT oxford white, 21Tundra
Yep. There was nothing about a screw in the Form video. Just did mine 2 weeks ago.
I did the reverse light with a 4th brake light also. It was easier, just more 7mm screws.
Did you have any issue with the 4th brake reverse light? I have 2 that I cannot get the connector to the light to mate.
exm
exm
Long Island, NY
Only did the side markers (front/rear). Rear markers hopefully in May, so I can't help you right now.
On a side note: I believe I read an issue with some of the rear lights connectors, Google it.
goodlettjr
Charlotte, NC
The connector was very tight. Use a bit of dielectric grease and it will slide together. Took me probably 3-4 times to get them to mate up. After that it works flawlessly.
DarkH95
2026 Mustang Dark Horse
I bought LED Side Markers for my car, and most videos have them pop-out with ease. The rears popped right out as expected. However, I couldn't get the front ones to come out. At all. So I went the 'official' way to remove the fender liner. I found out the front 2 actually are screwed in (no wonder they didn't pop-out). Not sure if this is for 2026 models, but I figured to share this here.
Top picture is the back of the OEM side marker, taken from inside the fender. Bottom picture is the screw.
Sorry for the dumb question, but how were you able to reach behind the fender liner and unscrew the bolt? I can’t seem to get any space to do so and I turned the wheel inwards as well. Thank you for the help!
exm
exm
Long Island, NY
It wasn't easy. But yes, turn the wheel inwards, remove the fender liner and from there one I used my cell phone as a camera to identify the screw. It's a bit awkward but doable. Much easier if you have 2 people.
DarkH95
Thanks!!! I’ll give it a try, did you just use a regular torx screwdriver or a different kind of tool to get it off? Thank you again, I usually never get any help from forums lol.
exm
exm
Long Island, NY
Regular torx screwdriver. It wasn't overly tight for me, so it came out easily.
Ninjak
Posting from the Shadows
The Shadows
I changed my markers to smoke LED. I did not have any screws...they were in tight; I just used a fork pry on it, and they popped out rather easily then.
DarkH95
Thank you so much! You’re a life saver and so goated. Appreciate all the help!
exm
exm
Long Island, NY
Yeah, that's what most videos are showing. I have a 2026 so I assume that it's a MY26 change.
BuckeyeBOSS
Yep. 2026 here and mine had the screws.
D/\rK•650
2025 Mustang DarkHorse
Hey can I ask you how difficult it was to pop out the rears on yours? Like did you have to take the fender liner and plastic rock guard piece off? I ask because I have mine sorta taped/lightly stuck on with black RTV silicone to keep it from flopping in. I want to get this but if I have to redo the side pieces then I'll probably skip for now. Thanks in advance exm.
exm
exm
Long Island, NY
Since you have a 2025 you can probably simply pop-out the side reflectors. Have you seen a video how to do that?
D/\rK•650
I'll have to check on that. I think there's one on the forums here. But do you think I would be able to pop them out without messing with the rock thing? The fronts if needed I can take liner off.
exm
exm
Long Island, NY
About 6 minutes in
It is super easy, I haven’t damaged anything using this method. Do the fronts first. If there is a screw it will be in the back. You will know if they really don’t want to pop-out.
Not sure if you have a jack or ramp, but you can also access these from under the car without removing the liners.
