Installed NOCO Gen 5 battery maintainer
The direct mount 2A version is installed on many of my vehicles. That way, no matter where you are, all you need is a standard electric cord to charge - no need to have the charger portion with you (it's installed on the vehicle). And 2A is plenty for maintaining and half the price.
Grabber1
Grabber1
Washington
The Gen.5 also came with a mount to install the charger on the car. Where did you Mount yours?
armyGT
Butler, PA
Since I want a permanent mount hidden as much as possible, can I just use the two terminals on the battery under the battery cover and hide the wires? Any pictures of this install?
Zuko
Wisconsin
21 F150, 25 GT Premium Molten Magenta Convertible
Following for when the 25 comes in nov.
Grabber1
Grabber1
Washington
I did a alot of reading before installing this tender. Lots. There is a Battery Control Module cross connect at the Battery. The BCM monitors the Battery and by hooking up at that location you will bypass the BCM from what I read. I'm not sure what exactly that will do to the system. As you probably know the way I hooked it up is also how you jump the car if the battery is dead per the manual.
Grabber1
Grabber1
Washington
My GT had 23 miles on it when I picked it up 6 weeks ago. It was built in April 2024 and took a while to be delivered. Then it sat another 10 days in my garage due to a warranty issue. Now that I can drive it, I wanted to make sure the battery was fully charged. These cars have so many electronics in them that can draw the battery down. I'm retired so the car will not get driven enough to keep the battery in good health. After 3 hours the battery is now fully charged.
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_163326
Sweet, I actually just bought a noco 30 lithium battery for race days, 4lbs.
Zuko
Wisconsin
Did you wire your 2a the same or straight onto the terminals?
armyGT
Butler, PA
After I read thru other posts it appears as though mounting Tender directly to the battery posts isn't a great idea since it might interfere with the Battery Control Module. I guess I'll use the fuse box positive and the ground post negative on the shock tower. I hope I can make it look neat. Thanks!
Grabber1
Grabber1
Washington
To clean this install up I installed some 1/4" flame proof auto wire conduit made by DORMAN. Now it all blends in. I also noticed the charger is now full green after 6 hours.
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_212404
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_211536
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_211509
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_211213
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_213645
Grabber1
Grabber1
Washington
To secure the end I drilled a very small hole in the hard plastic edge trim and inserted a super small zip tie into it. Then pushed the plastic trim piece back into place and tightened the zip tie into the auto conduit. Now when the hood is open it still looks stock.
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_214321
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_214412
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_214730
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_214741
DARK HP
nky
2024 Mustang GT/CS PP,2025 F350 Plat. TREMOR
Like the way you used the wire conduit on the X-Connect Eyelet Terminal Connector
I did the same with these parts from NOCO
Amazon.com: NOCO GC002 X-Connect M6 Eyelet Terminal Accessory Genius Smart Battery Chargers : Automotive
Amazon.com: NOCO GC004 X-Connect 10-Foot Extension Cable Accessory Genius Smart Battery Chargers
Amazon.com: NOCO GENIUS10, 10A Smart Car Battery Charger, 6V and 12V Automotive Charger, Battery Maintainer, Trickle Charger, Float Charger and Desulfator for Motorcycle, ATV, Lithium and Deep Cycle Batteries: Automotive
with the longer extension I plan on shutting the hood and run the wire down to the floor and plug into the gen10 so I can put my Ford performance indoor cover on my gt/cs pp mustang
Grabber1
Grabber1
Washington
With my set up I made sure the hood would shut and the NOCO Gen 5 tender would sit on the floor.
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_224641
S650 Mustang Installed NOCO Gen 5 battery maintainer 20240930_224457
Grabber1
Grabber1
Washington
The 2A version is 20 bucks less expensive from what I see:
NOCO GENIUS2, 2A Smart Car Battery Charger, 6V and 12V Automotive Charger, Battery Maintainer, Trickle Charger, Float Charger and Desulfator for Motorcycle, ATV, Lithium and Deep Cycle Batteries https://a.co/d/ifE1Bhx
