Infotainment wireless charger support
Ivan Yagüe
brazil
dark horse
Hi,
I get my Dark Horse a few weeks and since the 2025 DH in Brasil came without the wireless charger, I bought the oem charger sale from the infotainment.com web site. They have a very explained video about how to install, assuming that all the 2024/25 GT and DH without the wireless charger came with a pre wired plug for the charger.
Unfortunately, my DH doesn’t have the pre wire plug for the charger.
I tryed to contact then for more than a month, without any success. Nobody car about it.
I really would like to to install the charger, even if it not works perfect with the icons on infotainment screen showing information about charging.
anyone could help me to install it?
Cheers
Vapor
Western Pennsylvania
2025 Ford Mustang GT Premium
It is stupid that Ford give us wireless connect for our phones but not wireless charging :thumbsdown:
D/\rK•650
2025 Mustang DarkHorse
Hi,
Cheers
I don't think any of the 2025 DH come with wireless charging. Hence don't have the wire for it.. sorry to disappoint, call Ford to verify maybe?
jawsr101
lexington SC
2024 mustang GT
Wouldn't waste your time honestly. Have a 24 with it and it never works
MIne works great, have an iPhone 14 Pro Max with case. It does need to be in just the right spot but works with top of phone to left or to the right. I would check with ford if yours is not working right. Might be why they removed it.
mashi_taters
Bahrain
2025 Dark Horse 700A Blue Ember S1244
Hi Ivan, my DH 2025 also did not have it installed, I think maybe the OEM had issues, after trying random phone accesories with wireless charging and nothing was fitting nicely, someone on the forums here mentioned a 3D printed one from etsy.
I went there and found a member ADOUBLEU3D and ordered it, it fits perfectly and you can customize it to your liking. I'm tempted to buy one or two more just in case to be honest.
I think if you type his name or: Wireless MAGSAFE Charging Pad: Fits all 2024+ Mustangs , you will find it.
I customized mine to be blue and say Dark Horse.
I hope this helps,
Kindly,
Mo
Edit: it came with the wire having a usbc to usb converter so you can even use usbc or usb :D
Ivan Yagüe
brazil
dark horse
I hope this helps,
Kindly,
Mo
Thanks…
i will looking for
Send some pictures of yours if you have it.
Cheers
mashi_taters
Bahrain
Thanks…
i will looking for
Cheers
sorry for the dark picture, took it at 3:30 am 😅
the black thing in the middle is the magsafe it is magnetic and the white ring around it is small led i think cause it glows green, but it's under the phone so doesn't really matter.
S650 Mustang Infotainment wireless charger support 4017d8ae-f634-4dc4-92ff-d18bc27e451f
Ivan Yagüe
brazil
dark horse
Thanks
It is really nice
I will looking for
CheerS
Probably could power it from the accessory power port, it wouldn't give any charge indication on screen, but should charge... I did something similar in another car.
Mine too... exactly the same, has to be the right spot. Samsung S 23 w full cover case.
I think there were far too many issues with the charge pads (supplied by the lowest bidder), so they just quit putting them in.
Gene3
2024 GT
How does it install? I ordered from Etsy but when I remove the rubber insert from factory, it does not sit level. Did you remove the existing charge pad?
Thanks.
mashi_taters
Bahrain
Thanks.
in the 2025 it did not have an existing charger pad, it was just an empty cubby cause they did not have built in charging, and it fit there perfectly, i'm not sure about models that have a built in one :(
Dark Sprite
UAE
I can
I can't quite tell from the picture on Etsy, is the central charging spot raised slightly to connect with the back of the iPhone 17 pro? The stupid camera plateau means a lot of wireless chargers are useless for this phone, including the Ford charging pad in my Expo.
Mine works Ok now, after I got rid of the carbon phone case. But the phone gets hot, I won't use it on a long trip.
