How to fix snapped stud in strut tower
MustangNoob
CA
How can I fix this? The stud snapped while trying to torquing down to spec...
S650 Mustang How to fix snapped stud in strut tower tempImageAoK3kE
S650 Mustang How to fix snapped stud in strut tower tempImage6OaGPP
I'm guessing it's a captive bolt? If so, I think cutting off flush, drilling out and a new bolt and nut would be the way to go. It's going to be a PIA.
BTW what's the torque figure?
MustangNoob
MustangNoob
CA
41 lb.ft number is based on ford's installation instructions....The stud looks like it's welded in the back . The photo bellow shows how it is. Photo is taken from this thread https://www.mustang6g.com/forums/th...-brace-bolt-sheared-thread.81846/post-1887885
The guy just hammered it , others are drilling it to remove and they put a bolt there. Will have to reach out to them and ask them how exactly they did it. I'm planning to change my springs so there will be easier to work on that. Looks kinda trivial ..
S650 Mustang How to fix snapped stud in strut tower 1746669431731-c2
41 ft lbs shouldn't have broken that. I bet it has been overtightened before.
You can drill right through the bolt head, not so sure about hammering it out though.
38.9967° N, -84.6310° W
Regardless of what Ford Perf. Instructions say, I believe 41 ft-lb is too much. In comparison, cast/camber plate nuts get tq'd at around 22 ft-lb. But......I could be wrong........🤔
amir_gh
2025 Ford Mustang GT
Did you ever get this fixed? Same thing just happened to me
MustangNoob
MustangNoob
CA
yes. but it was done during a suspension upgrade, it was easier. The mechanic put another stud and he spot welded it from the bottom (similar spot to what the picture has). Clean work.
S650 Mustang How to fix snapped stud in strut tower 84E75519-678C-41A2-B82E-E835B58F525D
