How much negative rear camber are you guys running? Is 0° OK
RyanB3239
Washington State
2024 Mustang Base Model
Hi guys, I installed a 20 inch rim on my car My spec is 20 x 11 315/30/20 back tires and I noticed that I’m little bit aggressive on a negative side and when I did an alignment I am 2° negative, I know I’m within the spec since I lowered the car should I run at least 1° or .05 any suggestion I’m not taking this car for a track day.. only cruising and dinner date and some long scenic Drive or should I go all the way to 0° rear camber
S650 Mustang How much negative rear camber are you guys running? Is 0° OK IMG_7593
Interstellar
Dallas
C6 Z06
-2 degrees is fine. Maybe a little aggressive but if you're lowered on stock suspension w/o camber plates, there's not much you're gonna be able to adjust.
You're still well within factory spec which is -1.5 +/- 0.75. So -2.25 would be the max
Whatever you decide though, don't go with 0 degrees, that's dumb. you need some negative angle
S650 Mustang How much negative rear camber are you guys running? Is 0° OK 1709324295161
S650 Mustang How much negative rear camber are you guys running? Is 0° OK 1709324275280
F150 FX4, 2024 Mustang GT Vert PP NP
Agree -2 will be fine. I ran -3 in my former track car and had a lot of aggressive components...:sunglasses:
RyanB3239
RyanB3239
Washington State
I run -2 and it's fine for both daily and track duty.
What is your set up size on the rear tires of your vehicle and how much miles are you getting out of the tires when you’re running a -2° camber
RyanB3239
RyanB3239
Washington State
What tires are you running on your vehicle set up. -3 is pretty wild. I’m sure you’re getting inner tire wear like crazy.
RyanB3239
RyanB3239
Washington State
Thank you 🙏!!
Hoosier A & R7, 315/30-18. Car sits about 3" off ground at splitter & diffuser
JediMindTrix
S650 GT 401A (NP, PP, MR, AE, 10R80)
Tread still looks pretty good after 4K miles. I have 19x10 in the rear with Nitto G2 305s’ at the moment.
Ryunker
Madison South Dakota
2013 convertible, 1971 Mach1
Allergic to buying tires, 0° all the way around.
