GT shift lever shake
WayneK
WI
Mustang GT
When my GT manual transmission when running at idle in neutral the shift lever has a slight shake to it. Is this normal? My dad has a 2018 GT and his does not display this.
Dxm
San Antonio
Mine vibrates a little bit, if you put your hand on it.
WayneK
WI
Mustang GT
Mine you can see wiggle.
WayneK
WI
Mustang GT
Can anyone with a GT respond regarding shift lever at idle shakes when in neutral (manual Trans)
BrianJ77
Probably taking her out tomorrow. I'll check it out for you.
Gr8ful
S.Carolina
2023 Santa Cruz, V-Strom 650
Never rest your hand on the shifter except for changing gears. Per the manual.
JPGC_S650
SC
Yeah, it shakes a little from the vibration from the transmission through the remote linkage in the stock shifter assembly. Shouldn’t be shaking violently though. I have the MGW shifter now which directly mounts to the transmission and you can really feel the vibration, which I like personally.
Upacurb
Up a curb at cars and coffee
BrianJ77
So no visible shaking of the shifter. Slight vibration from the engine if you put your hand on it. Otherwise it's quite steady.
LoWeLL216
San Diego, CA
Mine does it slightly. I noticed when I first got the car, but no more significant than other manuals I've had.
