Fuel Gauge
Gr8ful
S.Carolina
2023 Santa Cruz, V-Strom 650
Im with Katara,same numbers
21.8 city, 1800 miles on the car.
Has anyone had the issue with their car getting around 25-30 mi until empty and then it just rapidly drops to 0?
For a variety of reasons. you should not let your tank get that low before filling up. Worst case, I refill at 1/4 tank.
I like the 1/4 tank fill up as well... gotta keep that in tank fuel pump cool!
DarkkMatter
Virginia, USA
Never know when a major power outage will hit, if you'll get stuck in bumper to bumper traffic due to whatever reason, or if something happens and there's a run for the pumps by society.
I always like to keep mine near full.
I definitely do that with my F150 and its 36 gallon tank.
wait, you guys fill up at 1/4 tank? i usually go till anywhere from 5-15 miles to E
Don't like the fuel pump much?(keeping it submerged helps keep it cool). My wife always drove our S197 down to that level, and then only put $20 or so in it, and it started having fuel pump problems later in life. Hope you don't run it that low on the track... or maybe you were just being facetious.😁
dunno how much cooling its doing when the fuel gets heated up in the Arizona sun, where it can get to 120+ degrees outside in the peak of summer. when doing autocross, i always fill up before leaving, regardless of fuel level. i also always fill up 100% and dont leave the fuel station until its full. i guess ill see when the vehicle is older what issues pop up with it
Less fuel in the tank means that the concentration of the "dirt" inside the tank that's mixed with your fuel is higher. This can lead to fuel pump issues, and also spark plug issues. Best is to fill up after 50% but 25% is good as well.
Lakersfreak
Los Angeles
24 Mustang GT
it's because you're driving either downhill or uphill and the gas gauge is being fooled.
kinelisch
Every car I have driven that has had this feature is unreliable below 1/4 tank. So, I always fill at 1/4 tank. My 24 stang is no exception.
Same. All my cars are inconsistent when its below the 50 miles left mark.
mine usually reads ~230 miles to E when full
