Battery Voltage Question - 11.5 Volts When Off
MidLifeCoyote
Peoria Illinois
I have a 2024 GT non PP with 17k miles. Last night I got a ford pass message that remote features were being disabled due to low battery charge. I do make short trips so as it suggested I took the long route to work this morning, about 25 minutes.
Both this morning before the drive (after the message) and this afternoon after work, my battery voltage on the dash said 11.5 volts before starting. While the engine is on, it reads 14.5 volts. I assume this means my alternator is healthy, but does 11.5 volts after about 7 to 10 hours off mean my battery isn't holding a charge well? Internet tells me battery should be around 12.5 volts when car is off, but both times at 11.5 volts the engine started fine.
MidLifeCoyote
Peoria Illinois
I can double check it with a multimeter tonight. Ford warranty language would seem to classify gradual capacity loss as wear and tear and thus not covered.
Anyone have experience with this?
GTSteve
Tulsa
I have the exact issue with my '24 GT. Ended up putting a charger pigtail on the battery and connect a battery maintainer during long idle periods longer than a week. One incident last August resulted in an "update failed" message appearing, however the battery hadn't reached the low voltage threshold to trigger the "battery saver mode" alert. After trying several times to manually install the update, looked at voltage on the center display and it was at 11.5V. Updated successfully after several hours on the trickle charger. Shouldn't have to do this on a 2yo car 🙄
MidLifeCoyote
Peoria Illinois
When I checked the with multimeter last night it said 12.2V vs the dash saying 11.5V. Called dealer this morning and they said they getting lots of similar calls lately. They said it's under warranty for 3years/36K but they have to do the whole charge and test which could take most of a day, so it would need dropped off.
I'll keep a close eye on it but may have them take a look next week.
GTSteve
Tulsa
Interesting 🤔 I may have to call service department and start a service ticket before my warranty expires. Hate having to drop it off though. Maybe I could drop the battery off? That way I won't be freaking out about possible door dings appearing!😆
Starship Enterprise
MD
2025 Mustang GT Premium
Your 2 year old car's battery health has been in slow decline from not using a Tender.
Should we have to use one? No
Do we need to? yup....
What is the purpose of the bms?
Starship Enterprise
MD
It's a band-aid fix to a car that has more electronic drain than the battery can handle when not being driven.
I guarantee you I'll get MUCH longer life out of this OEM battery by regularly using a tender.
Correct. The battery isnt holding a charge and probably needs replacement. I would hook it up to a charger overnight and see what it does first.
I just replaced my battery under warranty for a similar issues.
Its not the car its the batteries.
Starship Enterprise
MD
Not true if you are daily driving the car.
Maybe...But I think that point might be debatable. The alternator never brings a battery to it's peak like a Tender does.
But TBH, This debate could only be verified one way or another by a side by side controlled experiment comparison over a period of 3-5 years....who's doing that? lol
But you drive your car daily and still needed a new battery sooner than expected didn't you?
Its not debatable. You shouldn't need to put a battery tender on a car that gets daily driven. Period.
Not at all. Just use a voltmeter on a newer battery vs and old one over a few days and log the difference. Easy.
Yes. Because the batteries are garbage. As soon as I replaced mine, all my recurring problems went away. Its not a parasitic drain or the car. Its the battery. Seems like the factory batteries dont last long. There's plenty of evidence for this on the forum.
