- Joined
- Sep 22, 2022
- Threads
- 77
- Messages
- 2,676
- Reaction score
- 4,052
- Location
- Cave Creek, Arizona
- Website
- roketgamer.dev
- Vehicle(s)
- 2024 Ford Mustang Dark Horse
- Thread starter
- #16
oh, i must have missed your thread. the main holdup for me is money, an IPMA is especially expensive, but buying a takeoff should work fine. as for the VIN mismatch, it should be fixable with FORScan and the only real issue being FDRS asking for the VIN when a new session is made. the actual additions should be easy enough. the coax cable connectors are also kina expensive and tricky to set up the pins themselves. the main difficulty with the parking sensors is placement and alignment@roket I believe we are trying to do similar projects related to the IPMA & adding new features! I have a thread dedicated to doing that, but haven't gotten much traction.
I'd like to see if we could share info - adding 360 cameras AND front parking sensors would be an amazing addition to these cars.
From what I can tell:
IPMA would need to be swapped for a few reasons:
Insufficient memory available to process inputs (problem on older platforms/S550)Incorrect/missing inputs on LIN bus for additional sensorsIncorrect/missing video inputs for additional camerasReplacing the IPMA may present some issues via FDRS, as the VIN is encoded on the IPMA, and may control the availability of ford pass features.
Beyond that, we should be able to manufacture a new wiring harness OR re-pin the existing harness to correctly install and make the hardware visible to the new APIM. From there, it should be a Forscan session or two away.
