360 Camera Addition
this is a thread i am putting together for a 360 camera addition. i've already done a bit of research, but no actual progress towards the final product yet.
as of this moment, here is what i do know:
some F-150 owners have successfully added the 360 camera onto their non-360 camera models.
most Ford vehicles made after 2021 use the IPMA for this, but older vehicles use a dedicated IPMB.
non-360 IPMAs are physically missing a connector for the four cameras.
what seems to be every Ford except the Mustang uses the IPMA as a sort of pass-through, but the Mustang directly connects the rear camera to the center display.
the Mustang also seems to be missing another connector that is present on every other vehicle, but this connector seems to mainly take care of front corner radars, the CHMSL camera, and the add-on camera. there is nothing preventing the addition of some of these things
for some reason, the IPMA also handles blind spot sensing and parking sensors, so a front parking sensor retrofit may be possible
in total, IPMAs can have up to 5 connectors, 3 of which are on every single vehicle produced today. a beige connector that does mainly LIN busses, park aid sensors, and the BLIS lights. a black connector that mainly does front center and rear radar plus IPMA camera heating element and some other CAN busses. a light grey connector that is not on the Mustang which is the one that does CHMSL camera, front corner radar, and add-on camera. a brown connector with spots for up to 4 coaxial cables, used on the Mustang for IPMA camera and for rear view camera pass-through on all other models. a green connector with spots for up to 4 coaxial cables, which is where the four 360 cameras go if the vehicle has it. if there is a green connector, almost always the brown connector will have 2 cables coming out; one for the IPMA camera and one for the video output for the APIM. otherwise it will have 3 cables.
from what i can see as of now, everything looks very doable, however there are two unknowns currently.
1. how will the center screen behave with the new input? its used to just one camera directly, but this will be changing it to send a much, much more complex video signal.
2. how do we get the 360 to show up at the press of a button? the F-series trucks have a button that goes to a dedicated "Camera" pin on one of the connectors, but then that doubles down on point 1
here are the pinouts for each connector
ColorF-150MustangMach-EMaverickConnector that plugs into it
Beige
S650 Mustang 360 Camera Addition 1751355998426-zb
S650 Mustang 360 Camera Addition 1751356010099-8
S650 Mustang 360 Camera Addition 1751356555162-3u
S650 Mustang 360 Camera Addition 1751384109873-tc
Yazaki 7287-2047-30
Black
S650 Mustang 360 Camera Addition 1751356143819-yw
S650 Mustang 360 Camera Addition 1751356098318-5i
S650 Mustang 360 Camera Addition 1751356581292-n7
S650 Mustang 360 Camera Addition 1751384135733-wq
TE Connectivity 2288276-1
Light Grey
S650 Mustang 360 Camera Addition 1751356232690-0q
Missing
S650 Mustang 360 Camera Addition 1751356603281-7v
Present but unusedTE Connectivity 2288276-2
Brown
S650 Mustang 360 Camera Addition 1751356470258-40
S650 Mustang 360 Camera Addition 1751356274242-rv
S650 Mustang 360 Camera Addition 1751356688016-s5
S650 Mustang 360 Camera Addition 1751384192528-89
Rosenberger AMZW25-000-F
Green (360 Cam)
S650 Mustang 360 Camera Addition 1751356418664-7c
Missing
S650 Mustang 360 Camera Addition 1751356631515-i5
S650 Mustang 360 Camera Addition 1751384170495-qv
Rosenberger AMZW25-000-E
mabcim
Rochester, NY
64.5 Mustang Conv, ‘25 Maverick, ‘23 Escape
This is great info.
Not too surprised the video connections are different between 360 and non-360 models.
The missing plug is the hardest part. Not being there can easily mean the components, on the board itself, are also missing. And mostly like at a minimum, there are pull-up (or pull-down) resistors on some or all of the lines.
And with the pin on the other connectors being jumbled means the internals are different.
Based on this, the IPMA module needs to be swapped. And the wiring harnesses re-pinned.
What is interesting is the MachE and F150 have some pins different. I wonder if comparing to an Escape or ‘25 Maverick (which have 360) might be worth it. Maybe those would be an easy IPMA to worth with? I’m thinking this because those are the same size screen as the Mustang. And the MachE, I believe is Sync 4a, while the Mustang/Escape/Maverick are Sync 4; not sure what Sync version F150 was.
Looks like pin 10 on the black connector is the camera button. MachE is all touch screen, so that pin is not populated on it.
rugedraw
Miami, FL
2021 F150 701a 3.5tt 4x4; 1990 Mustang 5.0 coupe
On the F150, 360 views are enabled in the APIM here. Just pulled the ab data from a random 2024 Mustang and it shows an 8 in the field below which makes sense for rear camera only vehicles.
S650 Mustang 360 Camera Addition 1751381708366-s7
i did some looking on some stock units at work and found this very interesting thing
S650 Mustang 360 Camera Addition 1751383235297-db
IPMA in the back of a 2025 Maverick, and they just left the grey connector empty entirely
This is great info.
the pins are not jumbled, but its just the wording is different but usage is the same, but some are not used. for example, the beige connector pins 2 and 3 are unused on the F-150 and Mach-E because they light up the BLIS indicator via communication over CAN network. the Mustang and Maverick lights them up directly, though through those pins. this is also an option you can enable and disable in FORScan. the F-150 uses SYNC 4 as well. the general shape and mounting of the module appears to also be the same across all vehicles that use it. i also added the Maverick's connectors to the first reply too
true, i forgot about that. in fairness, i posted this thread at just before 1AM, so i wasnt even thinking about that
mabcim
Rochester, NY
Well look at, nice! Ford said they wanted to get to fewer screens, maybe they also went to fewer IPMAs; that would be good.
I was kind of wondering if that was the case, but didn’t study too much. So that is good news too.
thank you, this does have quite a bit of useful info. based on what i found last night and this morning combined with the info from there, i think its pretty straight forward from here (relatively, of course) to actually start the project. something in me says that a step is missing somewhere, though, and im not sure why. i planned out the connectors, IPMA, wiring, camera, camera mount fabrication, but im not sure what i feel is missing
mabcim
Rochester, NY
Mirrors? If you want side views. Not sure how you solve that though.
Not sure if IPMA needs any ‘Mustang specific’ things put on it; but probably not.
Other than that, time, $ and Forscan should be it.
side views will be easy enough. 3D print a mount for the camera, drill into the mirror, and run the coax cable to the IPMA
DT-GT
If you figure out a solution to the front issue I would be very happy!!! Good luck!
rugedraw
Miami, FL
This bit in the IPMA looks like an important piece of the puzzle:
S650 Mustang 360 Camera Addition 1751388416539-7l
My truck with OEM 360 cams shows FF there:
S650 Mustang 360 Camera Addition 1751388453970-pu
i managed to source all of the original connectors on the IPMA (except ethernet). it uses connectors from TE Connectivity, Rosenberger, and Yazaki. i have been getting better and better at finding connectors on Mouser
mabcim
Rochester, NY
Mouser is a great source for connectors.
V6S197
Orlando
2024 Mustang EcoBoost Premium
@roket I believe we are trying to do similar projects related to the IPMA & adding new features! I have a thread dedicated to doing that, but haven't gotten much traction.
I'd like to see if we could share info - adding 360 cameras AND front parking sensors would be an amazing addition to these cars.
From what I can tell:
IPMA would need to be swapped for a few reasons:
Insufficient memory available to process inputs (problem on older platforms/S550)​
Incorrect/missing inputs on LIN bus for additional sensors​
Incorrect/missing video inputs for additional cameras​
Replacing the IPMA may present some issues via FDRS, as the VIN is encoded on the IPMA, and may control the availability of ford pass features.
Beyond that, we should be able to manufacture a new wiring harness OR re-pin the existing harness to correctly install and make the hardware visible to the new APIM. From there, it should be a Forscan session or two away.
