2024 Mustang GT Light Bluish Puff Of Smoke.
GrabberB
2024 Mustang GT Performance Pack, 2024 F-150, 2000 Dodge Ram 3500 800 HP Cummins
I’ve changed around 700miles the oem exhaust also produce the same smoke.
Is the smell new? Just thinking the smell could be related to burn off on the new exhaust. Maybe condensation and new exhaust burn off.
S650sunshine
S650sunshine
S650 GT
I thinking that but I realize that the new exhaust smell already worn off a couple weeks after the install. This stink smell different than the new exhaust smell.
bfets
Western Australia
Have you noticed any fluids being consumed? Keep an eye on the oil level and the coolant level.
S650sunshine
S650sunshine
S650 GT
Coolant is the same level, oil does seems a bit lower on the hash marks, but then again I have the oil cooler.
bfets
Western Australia
I think you just need to keep an eye on it over some more miles and see what it does. Monitor oil levels etc. I'd also take it to the dealer to get it checked out. Even if they say its normal, you have it on record that you reported that issue, should it turn into anything nasty.
S650sunshine
S650sunshine
S650 GT
Yeah definitely I’m going next week just to have them check it.
bfets
Western Australia
S650sunshine
S650sunshine
S650 GT
Oh btw the smoke does look same as the that darkhorse, have you seen the video I sent?
bfets
Western Australia
I did. Its hard to make a direct comparison but on the DH it looked a little darker and less smokey to me than yours. On the DH it also dissipates very quickly whereas yours seemed to linger a bit longer to me. But I could be wrong obviously.
S650sunshine
S650sunshine
S650 GT
Oh well, have to get checked out I guess. Engine runs fine, no lights. Doesn’t sound like it’s sputtering or stutters on normal acceleration.
@S650sunshine .......bluish smoke is "usually" not good as it usually means oil. Blackish is usually over rich, white is usually condensation and bluish is usually oil derived like a faulty valve stem seal or ring failure. Take it to the dealer and have a work order written to log your visit for future warranty. I suggest you do NOT just ask someone to look at it and offer an opinion without formally recording the "investigation" via a work order - as this will protect you for warranty.
S650sunshine
S650sunshine
S650 GT
Yup I’m taking it next week.
That is not smoke, holy shit, it’s leftover water vapor condensate being blown out on start up. Holy shit.
People may as well just buy electric vehicles at this point, not you but others, complain about engine noises, cam chains, direct injectors, relays clicking.
“Smoke on startup”
Make the switch…
If that was actually smoke… it would stay smoking with rpm, driving, etc… all conditions
Again, it’s nothing more then condensate
Enjoy your new mustang, embrace the sounds and smells and characteristics of its combustion engine
8915GT
Mine smoked way worse and the dealer told me it is normal even though it is not. service advisor told me to wait until I hit 5k and do my first oil change. I took it with 1400 miles, i doubt they are going to do anything and probably just a waste of time but let us know, maybe you will have better luck.
S650sunshine
S650sunshine
S650 GT
“Smoke on startup”
Make the switch…
Absolutely I’m enjoying it, everything else runs perfect.
