Vapor Blue GT
Mustang and CRV
I had my car looked at for this exact noise a month back. The master Tech explained to me it was the Check Valve on the PCV. Essentially there is a small metal ball on a spring to open/close the PCV valve. As the car runs it open and close in no orderly fashion, just as it needs. So this is no real threat or thing to worry about, is kind of annoying though.
Glad you found the culprit. The other thing interesting is that I’ve never seen a ball in a pcv valve. Just a spring and a piece of metal or plastic. I’m now curious as to what our pcv valve looks like.
Jerrym1k
Northern Virginia
2024 Ford Mustang
Mine has developed this tick after its first oil change. It might be my mind but it seems to have increased in volume.
DCS
Ocala, FL
This almost sounds like an ignition spark going to ground. It's random.
The morse code noise or the rotating assembly sound?
Dave2013M3
El Segundo,Ca
1/2 bottle of liquimoly ceratec and it's gone
Jake H
2024 GT PP
This is the noise from my passenger side valve cover. Never heard this sound before. Once again, 1st change has been completed and car has 920 miles on a Dark Horse. It’s not a constant sequence, definitely moved everything and made sure it wasn’t just something rattling against the vale cover.
My car does this exact same thing
Petes24Gt
My2024mustanggt
2024 Mustang gt
Use high octane only it’ll go away
