Widest rear tires on a Dark Horse
The dark 1
2024 dark horse
What is the widest rear tires anyone has installed on a Dark Horse?
Did they stick out past the fenders? Pictures?
I bought a set of 19x11.5 rims with 55mm offset for the rear and want to fit 355/30/19's if possible.
I plan to install michelin PS4S.
I have the handling pkg if that makes any difference.
ISLAND DARK HORSE
Chemainus, BC
2024 Dark Horse Race Red Premium Performance Recar
355! Not a hope.
They will definitely stick out past the fender and will contact the inboard damper.
I am running 19x11. 5 Apex with 325/30r19 Goodyear Supercar 3R, and I still needed a 5mm spacer to clear the damper running 2.5 degrees of negative camber.
Also, be aware that all tires do not measure the same. My Goodyears are significantly wider than a comparable Pirelli Troffeo.
im running 355 with rear tires, also Michelin Pilot Sport 4S. i needed some custom wheels so @Project6GR Wheels hooked me up and re-drilled some 19x12 Corvette Z06 wheels for the Mustang bolt pattern. you will not fit 355 width on 11.5" with wheels, at least not properly. 355 width tires will also contact the inside of the rear fender well when the suspension is compressed a lot. it wont cause any worrying damage to the tire, but mine is beginning to have the rear wheel arches forcibly flared out and the paint is slightly cracking. im also running 325 fronts on 19x11 wheels, with the offsets being +24mm front and +46mm rear. i had issues where the handling package fender flares got worn down by the tire so i just took them off. you will clear the struts and shocks, but barely. honestly, i dont recommend it. use your current wheels to run 345s or have a plan for a widebody kit
DevilDog
Northern Illinois
2024 Mustang GT on order
I don't have a Dark Horse, but I'm running PS4S 325's on my GT. Don't know if the offset is different on the Dark Horse or not.
young at heart
Deep South
Wow you must have some serious motivation up front to need 355s.
And here I was thinking the 315s looked really big on mine.
from my experience, 355s give you the ability to go full throttle from a stop on less than perfect roads and have no wheelspin with 500hp. plus, you get to say you have the same width rear tires as a Bugatti Chiron and Pagani Huayra
kinelisch
Can you post a link of the specific Rims and Tires?
DevilDog
Northern Illinois
I have the Project-6GR 10-spoke wheels in gloss black on my car. I believe I have the 19x10's on the front and 19x12's on the rear, but I could be wrong. My car is in storage, so I can't look at it right now. The folks at Project-6GR were great to deal with. I'm don't know how to post pictures on this forum, but if you pm me your number I'll be more than happy to text pictures.
The dark 1
The dark 1
2024 dark horse
Just a quick update, the 355's rear and 325's front fit without rubbing or sticking out past the fenders. In the front they are very close to the struts, but after 200 miles no rubbing so far. I haven't pushed it past .7g's so I may need a 10mm spacer in the front. We will see.
Please post some pics, we need to see that.
yes, please post pictures of that. no offense, but i dont believe it one bit. mine stick out probably half an inch and this is the clearance to the shock
