TSBs, SSMs, and recalls for the '24 Mustang
Thanks for posting.
Items One and Two seem more like annoyances. Item three though...I read the announcement several times.
I can understand messaging, authentication and self-checks. And I can appreciate the complexities of software. Until a fix is designed tested and available, reads like Owner's will need to be attentive for additional messages.
If only the specified message is present, ABS should would as designed.
If additional messages are present, ABS might not work as intended.
‘during a diagnostic self-test’. In other words during post (power on self test)? That would be the result of bad code/programming. It would seem someone forgot about error trapping. ‘Missing message’. The message is, there is no message? Should be a fairly easy patch.
diagnostic self test is done when a tech commands a module to test itself
Thanks for posting.
based on the wording, it's a nothing code; does nothing and you have no reason to worry
2 more SSMs were released
1. 51896 - "Lap Timer Results Greyed Out And Not Available And New Lap Timer Session Does Not Start At Lap 1 When A Lap Timer Session Is Stopped"
Some 2024 Mustang vehicles may exhibit a condition where a new lap timer session does not start at lap 1, the lap timer results are not available and/or the lap timer results button is not selectable. This may be due to the SYNC module (APIM) software. Replacement or reprogramming the APIM will not resolve this condition. Inform the customers that engineering is currently working on a solution for this condition and will be released via Ford Power-Up software updates delivered Q1 2024. Software will update automatically if vehicle connectivity is enabled in the vehicle’s settings. Schedule a service visit for customers who have disabled vehicle connectivity or who report that they did not receive the update in Q1 2024. Monitor OASIS for additional information.
2. 51898 - "DTC U3000:49 Setting In The Driver Seat Module (DSM)"
Some 2024 Mustang vehicles may exhibit a diagnostic trouble code (DTC) U3000:49 (Control Module: Internal Electronic Failure) in the DSM with no symptoms present. This may be due to the DSM software. Replacement of the DSM will not resolve this concern. DTC U3000:49 can be cleared and ignored if the power seat functions are working properly and no other DTCs are present in the DSM. Engineering is currently working on a solution and software update is expected in Q1 2024. Continue to monitor OASIS for additional information.
I almost wonder if mc the driver seat sensor and the rear seat reminder ssm are related.
since there aren’t rear doors how is the rear seat reminder triggered/tripped/set
Edit: what the heck is - ‘mc the driver’ ? Lol, typo. Should be wonder if the driver seat …
a TSB has been released. from now on i will be updating the main post and putting a reply when it's updated
new TSB for the EcoBoosts
new SSM released yesterday
Thanks for sharing this stuff! Any details on the new one, or where we might look for those?
i will always update the main post with the new SSMs and TSBs, as it's easier to track that way
marcekb
Ah ok, thanks! I figured I'd just missed some of that from earlier.
goodlettjr
Charlotte, NC
I noticed you did this and thankful. Can you put the date of the SSM or TSB so we can easily reference them? I assume you would put the date of the article and not the day you posted it.
went ahead and added that, the SSM/TSB number is now underlined too for clarity
two new SSMs came out on October 23rd, both relating to A/C concerns
