Tips for photographing black cars?
Redback
2024 Mustang GT PP 301A Manual, Shadow Black.
If you still don't like the images, there's an inexpensive fix. Purchase a small polarizing filter that's big enough to surround your lens (phone or camera lens). Watch the image in the device view monitor and rotate the filter 90 degrees either direction until you see what you like. Presto! No reflections. Problem solved. I'm a retired a photographer of 50+ years. For pros, a polarizing filter is a must-have tool. Good luck.
Not to be a smart-ass, but on a black car reflection is part of what conveys the shape. If you look at the picture of mine, particularly down the left-hand side and the hood, you will see a lot of reflection of the environment, and this contributes to the overall perception of the shape. A polarizer, as you suggested, can remove a lot of of that. But imagine if that reflection was not there. It would look very flat.
Deleted member 65426
Guest
This is exactly why you rotate the polarizer filter to your preference. It's not an on/off situation. You rotate the filter to remove just the amount of reflection you want. Just a bit, or totally no reflection. This is why they are designed to rotate 360 degrees. Rotate is slow and you see the effect. No professional photographer is without one. Landscape photographers use them to make streams and creek water clear. Architectural photographers use them to render window glass clear. Removing reflections is essential to precision photography.
Redback
Agreed. There are many circumstances where a polarizer will contribute to the clarity, definition, colour saturation of an image. My only point is that in this circumstance, reflection is your friend. Particularly if your goal is to emphasize the lines and contours of the vehicle. Removing reflection may be essential to the type of photography you mention, but it is reflection, and reflection alone, that defines the outline and contours of a dark subject where shadows are not visible. The more you remove, the less obvious the outline and contours will be. But, as you suggest, the OP can give it a try and dial it in to his liking, and see what he prefers.
glenng6
Easton, PA
I’m floundering around with how hard it is to take decent pictures of a black car.
The car looks phenomenal in-person. Its contours and shapes are captivating and compelling. But in photos, all the details seem to “moosh” together, and get lost in a big blob of black. Suggestions / hints?
Beyond waiting for “golden hour” (which I acknowledge I should do) 🌅
Thanks, guys.
As Snakebyte said, anything that reflects the light back onto the subject will help. Even parking next to an object that is a light color. Of course, you need to be standing between that object and the car. It's all about the lighting. And don't forget a photographer’s best assistant, post-processing. Even an application like Photos, on Mac, can make a big difference between a good photo and a great one. Glenn
Sometimes just the reflection is the shot you wanted...
S650 Mustang Tips for photographing black cars? 20231031_172934~3
wireeater
2025 Shadow Black Mustang Dark Horse
Don't take pictures of them in bright day light. Wait for sunrise/sunset times to get the best results.
OldCoastie
Kissimmee,Fl
Here is a photo that I took at sunrise, yes silver cars are hard to photograph too for the opposite reason no reflection and the lines blend in... This is my 63 that I restored at Ocean City, MD.
S650 Mustang Tips for photographing black cars? IMG_0577
OldCoastie
Kissimmee,Fl
Just took this one today of my new Mustang GT. So its both in the shade and sun and it really accents the color and the lines. Background is dark making the car the star of the shoot; Now one thing is the black stripe is a flat or satin not a gloss which allows you to shoot in the mixed light condition. Using processing helps with shadowing and color balance. This was shot with a Nikon Z-9 Camera using a 28-70 F-2.8 lens, all natural late afternoon light. Used ASA 800 and low speed 160 and used F8. no variances. Process using Lightroom. Hope this gives you some insight.
S650 Mustang Tips for photographing black cars? 597744-0094b86110250e98645fb2abd1b4f31f
glenng6
Easton, PA
Nicely done! The car looks great! Glenn
Redback
Beautiful!
