Tail light cover horsepower increase.
Redback
2024 Mustang GT PP 301A Manual, Shadow Black.
So I installed tinted tail light covers today.
After a lot of research I realized I had completely overlooked one of the most powerful performance upgrades available to Mustang owners: tinted tail lights. I discovered that when installed, they become advanced “aerophotonic modulators” that initiate a cascade of scientifically ambiguous processes that measurably increase horsepower.
I Googled what the experts refer to as Rearward Luminal Compression (RLC). It turns out that untinted tail lights scatter unregulated photons in all directions, creating chaotic light turbulence behind the vehicle. This turbulence interferes with the laminar flow of particles around the car. By tinting the lights, the photon emissions are slowed and compressed into a denser beam of high-performance darkness, dramatically stabilizing the vehicle’s wake.
Once stabilized, the car enters a state known as Optical Drag Reduction (ODR). Darkened tail lights absorb stray red-spectrum photons that would otherwise bounce off nearby pavement, buildings, and the occasional pedestrian. These photons are converted through a process called Photo-Thermo-Equine Conversion, where excess light energy is transformed directly into additional horses inside the engine. Performance experts refer to these as Spectral Horsepower Units (SHU).
Incredibly, testing in highly questionable wind tunnels has demonstrated that every 10% increase in tail light tint density produces approximately 3–7 phantom horsepower, depending on atmospheric pressure levels and the driver’s sunglasses.
There is also a psychological component known as the Observer Intimidation Coefficient (OIC). When other motorists see the darkened rear lights of a Mustang ahead of them, their brains subconsciously interpret the vehicle as moving faster than it actually is. This creates a localized relativity effect in which the car effectively gains speed simply by comparison.
What’s really cool is that the tinted lenses act as Equine Resonance Chambers, harmonizing with the engine’s combustion pulses. At exactly 3,500 RPM, the tail lights begin oscillating at a frequency that aligns with the natural vibration of imaginary horses, encouraging them to run harder.
I know traditional upgrades like a supercharger or exhaust system add significant measurable power, but if you’re looking for an edge, tinted tail lights leverage aerophotonic science to unlock the Mustang’s true potential: horsepower derived from darkness itself.
And they look great.
Long live the darkness.
S650 Mustang Tail light cover horsepower increase. IMG_2154
jboogie1289
Friendswood Texas, 77546
I’m reading your story with such intrigue and almost “Ahhhing” at it knowing or NOT knowing that any of it is fact!! Lmbo, it was a good read and those Tail Lights look Amazing!!!
Great job!!
sturner002
Chapin, SC
Which ones did you get? I want to make sure I get the ones with the best HP gains! 😆
Cipis
czech republic
Mustang GT
Just drive in dark night without lights, you will see how faster the scenery passes by…. That is like double horse power… Even better gain! 🫢
Neggytive
another option is hydrogen gas. if you perform a big enough smoky burnout, you might even unlock the #hindenburgeffect😉
I like your "outside the box" thinking, but for the safety of tire monkeys like me, Helium is the less fatal option.
There have been instances where some of the "fix a flat" products used propane or butane as the propellant. When air was added and removed to the tire it got the gas mixture down to the point a spark would set it off. Granted we worked with more steel wheels back then, but that tire bar rotating around the wheel could cause a spark and then there was a BOOM
There were also cases when people were plugging a tire, running the reamer in the hole to get it ready for a plug, hitting the steel belt, a spark happens and BOOM.
https://tiredefects.com/aerosol-tire-inflators/
Cipis
czech republic
Mustang GT
Boom, flying high…
RJW
Middle Tennessee
2011 Mustang GT, 2013 Ford Focus
This would make no sense on a black car like the one in the OP, but I wonder if anyone has ever painted the black tail lamp surround body color? I've been to a few Mustang rallies since the S650 came out, and I've never seen this done. I would think that on a lighter colored car like white, silver, or yellow, it would stand out.
Great for seating tyre beads.
Neggytive
