Stupid drivers doing stupid things…
Donj02
Missouri
That tech at the end walking between the cars was so close to having his whole life changed for the worse.
FarNorth
The frozen north
2024 Mustang
Like it so far. I used the usb connection on the rear view mirror. I placed the interior camera right below the rear mirror, and the main unit to the right and below the mirror (so basically just below the built in camera module). I ran the rear inside the upper liner to the A pillar, then into the door seal, then to the B pillar back to the C pillar. I probably have 10 ft of wire tucked into that C pillar on the passenger side then in the headliner to the center for the rear camera. Do the rear wasn’t so much difficult, just a bit hard contorting my body in the rear seat to do it.
My only gripe is that I have to manually turn the camera module on/off as it doesn’t always turn on/off automatically with the usb port. I have the hardwore kit but thought I’d try this first.
There is a plug you can add to your OBD2 port (Amazon) which will turn off after a few minutes when you turn off your car. I use it on my VIOFO and it works great. No issues.
https://www.amazon.ca/Aramox-18-9in...448&sprefix=obd+switched+plug,aps,146&sr=8-20
DontHitMeSafetyYellow
Philadelphia, PA
2024 Ecoboost Premium
No brakes in the Town Car??:frown:
It had handicapped controls (in addition to the standard ones). Owner said the standard controls DO work unless she hit some combination of the handicapped controls (which is quite possible. Look how long it took her to start and begin moving the car).
And yeah that almost was a LOT worse than it ended up being. That young tech might have had his legs crushed.
Philadelphia, PA
I'm not a defensive course instructor by any stretch of the imagination.....but in the case of the service truck passing the semi on the shoulder..... Other drivers on the road need to note the circumstance and allow the service truck space to either switch lanes or cross the line a bit.
If I had been able to SEE the rig pulled
on the side, sure, but I couldn’t from where I was and with the traffic. And you don’t swerve into other lanes if there are cars there! You can’t tell but I had to hit the brakes pretty good there as I was accelerating to move into that gap when he swerved.
Klipshpoke
2024 Dark Horse HP
Fair enough, that truck didn't show up till the last second.
One of my biggest peeves is when there is a vehicle on the shoulder and people in the left lane won't slow a bit to allow folks in the right to get over for a couple of seconds.
Philadelphia, PA
Finally got her back yesterday…
Dealship called back on July 3 saying the replacement part was in. I was out of town so scheduled for the repair on Monday.
Monday I show up at 8am. They tell me it should only take a couple hours so I figure I’ll wait and work from there.
2.5 hours later the service manager comes to me to tell me that they ordered the wrong rear bumper cover unit. They didn’t notice I had quad tip exhaust and ordered the one for dual tip (how?!?! Its stock!!! Looking up the vin should have told them that!!!). Sigh. So they gave me a loaner Bronco Sport.
At least it’s finally all fixed back to original condition. But, seriously, after all the idiotic stuff I’m seriously considering switching to Winner Ford instead of Holman, even though I used Holman for a decade with my 2011 Explorer. They just do not give me the warm fuzzies after all these issues.
I didn’t even mention that when they did the oil change on the 29th and the tech sent me the multipoint inspection video, when he showed himself measuring the rear brake pads, he measured the E/drift brake, NOT the rear Brembos!!! “Oh 5mm, you’ll want to get this serviced soon.” (Moron!!!!). I mentioned this to the service manager yesterday when I picked the car up that he might want to have that tech retrained…..
Paul's stable
Maple Ridge BC Canada
Are you saying the USB port on the rearview mirror is ALWAYS powered - even after you have turned the car off? If so, many people would say that is a plus! Great for monitoring your car while parked. Also a battery drainer. 🤬
The mirror and lighter are on when the car is on but the car goes to sleep after 30 minutes once turned off. So they go inactive until you start the car again. My camera is plugged into my mirror and my radar detector is in the lighter plug. And leave the car sitting for days with no problem.
DCS
Ocala, FL
They did a multi-point inspection video? Is that required by FMC?
DCS
Ocala, FL
it’s something that dealership has done for years. You get a link texted to you with the video of the tech checking everything.
If they are that inept, you'd think they'd stop the practice. Otherwise, a great idea.
The cutting room outtakes are money.
SSuperDave
Friendswood TX
We use the video as well in our Quicklane, customer seem to love it ane when you show their actual filter coming out or dirty fluids, its easier to sell services. We do it on every car, regardless of mileage. Lot of people don't need anything.
abercul
North Carolina
2026 Ford Mustang
