steering , exhaust-----ridiculous
8LAKK8UNSHINE
Shelton, WA
2024 Mustang GT Premium Performance Pack 401A mag ride MT - Boosted
To unplug advancetrac (which I do not advise), you open the hood. Look on the right side near the fender and there is a plug that is pigtailed at the end. If you unplug taht, it unplugs advancetrac altogether and it will not intrude. ABS still works, but no advancetrac. Advancetrac has a certain level of intervention even in track mode, but if unplugged it's gone. Some people will swear that advancetrac can cause as many problems as it solves. Particularly if using bigger stickier tires than the car came with. I had an issue once where advancetrac did all kinds of whacky crap and tried to save me but interpreted my driving incorrectly and I lost the ass end of the car to a 270 degree spin. I don't use it or traction control at all anymore in dry conditions.
You guys are lucky.
As per regulations from 2024 onwards, here is the routine for someone in the EU each time we start the Mustang :
. Turn off automatic audio alert for the speed alert (including if one drives at >30km/h in the city)…
. Turn off automatic lane assist
. Turn off driver assist mode (hands on wheel !)
. Finally, put the car in the actual drive profile we want.
One wonders why the EU is not popular…
They do hate cars and drivers don't they. The funniest thing though, the UK left, but still have all that crap on their cars too.
I usually just select custom, that turns off stop/start, sets sport exhaust and steering, then I just kill lane assist.
Good to go.
Fruitstang
2024 Mustang GT Convertible
@8LAKK8UNSHINE
I highly doubt that stickier tires increase any kind of risk. The better the grip, the better it works.
And I also cannot imagine it makes you spin, in fact, quite the opposite, if you try to drift, it will not allow you to do that.
Maybe there was a defect or something in your case(?).
The reason to turn it off is to my knowledge to allow drift and slide to go through corners faster in situations where a controlled drift gains you time.
But in situations in which you have to immediately and harshly turn left or right to avoid a collision, not even the best driver in the world can outperform ESP.
The Mustang V had no ESP and many wannabes crashed it.
8LAKK8UNSHINE
Shelton, WA
I can't speak in terms of data bc I have done no real testing. Most of the claims out there are anecdotal. From what I understand, advancetrac, or ESP, works based on how it is tuned to the car with it's suspension geometry and tire setup. When any of that changes drastically, it may change how the system works (just like anything). The system workd by interpreting what it thinks the driver intends and the situation. It may cut accelation, brake, or accelerate and intervene. The system isn't always correct. Just like with lane assist or any other system - it is theory and not perfect. People tracking their cars have been making claims about experiences with advancetrac for years and some of us chose to unplug it and avoid intervention. I'd like to see data on that, but at this point we have no hard facts.
gtstang462002
Hollywood, MD
The advancedtrac from Ford is one of the best stability platforms on the market to date. It utilities gyros and accelerometers to measure angle of movement vs angle of desired movement from steering wheel position and other inputs. Drifting does not fit into standard driving profiles for the street. That is the only reason to disable it in a controlled environment, IE a track. On the road it could potentially save your life when you are going sideways in an unintended manner, IE sliding on ice. There are very few drivers in today's world that benefit from disabling this system and I would not advocate for them to do so in a public forum.
***Side note: if you are involved in an accident and your insurance company does an investigation and figures out that you have unplugged the nanny plug while driving it on the street, they will drop your claim.***
GrabThatBlue
Between Canada and Europe
You guys are lucky.
Turn off Lane Asisst by start up:
706-02-01: 6A67 0000 0*--
You have it set on (3) like European Mustangs
Change it to (0) for American Mustangs
Update: DOESNT WORK!!
8LAKK8UNSHINE
Shelton, WA
At this point I'm in my rear view watching to see if the hall monitor is following me to the track, ready to report me to State Farm.
Billycar11
no need they are already in your dash screen if you look through the settings there is an option is send data to insurance
its disabled for now likely because of the backlash GM faced but the toggle there just grayed out
Fruitstang
I tried it and it threw tons of error messages on the display and warning chimes started once ignition was turned on.
Where did you get this info? Livinitup list doesn't list any options for this parameter.
GrabThatBlue
I compared it between the EU Mustang and the NA Mustang.
706-02-01: 6A67 0000 03-- (EU) vs 6A67 0000 00-- (NA)
That lines changes the behaviour of: FeatureCfg_LKSIgnOnStrategy (FCLKSIOS)
it defines whether LKA (Lane Keep Assist) is ON or OFF after starting the car.
Since mine is turned off by (0) and yours is (3), there is a difference in this.
But yeah, you got errors when changing it, that means either this is not the only line to change to get it to work, or it will not work at all.
bee bop
Temple, GA
My biggest gripe about the custom settings is it is not fully custom. the magnaride settings are locked to the drive mode. For example, say you want the normal trans shift setting but the sport shock settings that is not possible because as soon as you select normal as the base setting the shocks are locked in normal mode. You can change the steering and exhaust to whatever you want.
I don't mind not getting Magneride now. It would be useless to me if it's tied to mode.
I often had my last car in full fat everything and shocks in comfort for rough roads.
Ewags81
Midwest
2024 dark horse
i do agree with you guys. wish i could mix and match like sport suspension and steer, track throttle, track exhaust.... but i imagine the throttle/suspension is tied together so that power application is more efficient and matched. also probably REALLY complex to get all of the cars systems to cooperate and work together if mismatched (traction control/advancetrac/abs/ecm/bcm/etc)
VileKnight
DFW
2025 GT
That isn’t a door the insurance companies want to open. Unless it’s written into the policy as required for coverage, they are not on very good footing if someone sues them for dropping them in that scenario.Worst case they process your claim and then drop you after.
