Spacers for Magneride
Zuko
Wisconsin
21 F150, 25 GT Premium Molten Magenta Convertible
Just a heads for everyone. I’ve seen where some people say you can run 20mm spacers on a magneride car and they’ve had no issues. If this is you then you should check them again. Just installed H&R supersports and steeda 20mm spacers and at first it looked flush. Spent a lot of time getting different angles and can 100% confirm 20mm do NOT work, it’s hard AF to see. Most angles it looks flush. I know most are running 25mm, but I’m case anyone thinks you can do 20mm, you can’t.
they don't work as in they aren't flush or they physically will not work with the OEM wheels without trimming?
bgold87
Louisville, KY
2024 Mustang GT PP
kinda of the same thing. If wheels don't sit flush with the hub, it's not going to work. But you 100% need to trim the studs.
What are these spacers? Why are they needed? Where do they go? What is being spaced 20 extra mm or 25 extra mm?
Alan1965
Stockton on tees England
Mustang GT s650
Confirmed, 25mm spacers fit on a PP with Magnaride. S650 PP wheels have a pocket that fits over the exposed studs.
Thanks for the information on the wheel spacers, on a magnaride
Thanks for the information on magnaride wheel spacers, I'm picking up a new 650 in 2 weeks time, this will be my first mod
