no, its just where i would normally put it there is a mount for the F77 JB welded in place. its not going anywhere
i had enough on my way home from work today. i couldnt stand seeing that $330 camera flopping around like damp toast. i took out some pliers and broke the JB weld. i am returning this camera for sure and getting my money back, or at least putting it towards a better camera. thankfully i kept the box and everything. that camera was as good as useless flopping around and i would rather drive with no camera
I ordered the Viofo A329S 3 Channel camera. Maybe something for you?
probably not, my A229 Pro kept weakening microsd cards to the point where it wouldnt record. probably will not be getting another Viofo unless it has built-in memory
finally got some pictures of the amber lights. first ever US owned Dark Horse with the amber DRLs, second ever Dark Horse in the world with them
S650 Mustang roket's Dark Horse - "Azureus" Project 1747975454524-fu
S650 Mustang roket's Dark Horse - "Azureus" Project 1747975475013-eu
S650 Mustang roket's Dark Horse - "Azureus" Project 1747975506700-1b
i ended up buying that one. apparently it comes with a free 256GB card at the moment, and that will last me until i can get an external SSD setup done, which i am glad it supports
I wonder when you get it. I bought it 1 day before you but shipment is very slow, so probably I'll habebit 2 weeks later than you.
Haven't seen any shipping details yet. Maybe it's not in stock yet?
their website says "shipping around May 27th"
goodlettjr
Houston, TX
I have the A229 Pro. Can you explain what is actually causing the micro sd cards to weaken. Curious what to look for because I don’t think I have had any issues.
i have no idea. all i know is that something is causing the microsd cards to last 6 months then the camera cries about "card slow"
Happened to me with several devices. It's the card, not the camera. Especially when the card is used a lot of times and gets overwritten a lot of times, the quality degrades. I had a lot of Samsung performance SD-cards with the same specs, bought in bulk. Some died very early and some I still use to this day.
Billycar11
mirco sd cards just dont have good durability to alot of writing best to buy the highest durability ones available sandisk and Samsung have a range of high write durability cards
i think im bordering on too many ideas at once, but i got a 3D scan of a few other things, and i had an idea for a custom headlamp switch to control a bunch of stuff.
i could put together a switch with 6 total buttons by combining the faceplate and left and right button clusters from specifically a 2025 F-150 PowerBoost, along with the rotating switch from an overseas Bronco or an Explorer Timberline. here's my thought process
for the PowerBoost part, it has to be specifically that because for 2025 Ford consolidated the mirror zone lighting to the headlamp switch on the right side; an area previously only used for the Mach-E traction control and overseas for headlamp leveling. this means that it has two buttons on either side.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748221674558-1x
for the Bronco part, this is thanks to european vehicles needing rear fog lights, but the Bronco also having front fogs, creating this switch.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748221830491-p8
the Explorer Timerline switch is pretty similar.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748222000291-pc
from there, i think its pretty safe to assume that the upper-left button will still release the trunk, but i will test to make sure. after that, i can find a matching color spray paint to the color of the plastic, blank out the buttons, then etch out my own icons on them and wire them up to do what i want. that will give me 5 blank buttons to do as i please with. the assembly part works because all of these switches are modular, just pieces that snap together. left button cluster, right button cluster, central cluster, and faceplate
small edit: it looks like another good left and right button cluster headlamp switch is one for a 2025 Super Duty with zone lighting, electronic release tailgate, and bed lighting
a teardown reveals that this will likely work. they are modular, and the buttons are the membrane style ones
S650 Mustang roket's Dark Horse - "Azureus" Project 1748225154637-o8
S650 Mustang roket's Dark Horse - "Azureus" Project 1748225167547-5t
i have decided to go all-out on the extra buttons thing. i will be doing an overhead sunglasses holder delete as well so i can fit 5 of those double buttons from the F-series trucks.
S650 Mustang roket's Dark Horse - "Azureus" Project 1748370663247-h
i got the ones without the "ON" text. this means i will have 15 total buttons to do whatever i want with
