rear rotors extra excessive play
Stang24
Chicago
2024 mustang
Having this chirping noise coming from the rear wheels just over 500 miles on the car. Took off the wheel and the rotor has some excessive play in it. Here’s the noise and that video of the rotor. Thinking the noise is wheel bearing or now rotor related…..
bridge4d
Mustang
I've seen some loose fitting rotors over the years so that's not unusual. How tight were those lug nuts on when you first removed the wheel? Make sure you torque the lug nuts to 150 lbs/ft (that's what's required for the s550, I assume its the same for the s650). That should sandwich the rotor in there well enough to prevent any movement. If that doesn't work, back to the dealer.
Stang24
Stang24
Chicago
2024 mustang
Checked them all and torqued to 150 the sound is still present
Did you spin by hand the same way you did just the rotor to see if it’s still doing it after torque…
slowjim
24 GT base manual
150ft/lbs on the lug nuts? that is WAY too high
slowjim
24 GT base manual
Oh wow, nvm then.
slowjim
24 GT base manual
I stand corrected, on cars I've owned in the past it was closer to 90-110 range.
I was surprised also. Its was always 95 to 110. Never had a wheel fall off in over 50 years. The 24's must have some super studs.
goodlettjr
Houston, TX
Axle nut in combination with the axle thrust washer is a plausible issue. Take it in sooner rather than later.
Adautomotive
Belgium
Dark Horse
Hi
Hi i had the same problem left and right and it drived me crazy. Living in Belgium and dealers don't know anything about these cars. And Having my own garage i searched and searched and finnaly today i fixed the problem. You don't need New bearings or halfshafts. You just need to put some ceramic paste at the end of the bearing where the halfshaft sits on and voila noise gone. I included the link that explains the probleem 200%.
