My S550 developed that at about 55k miles. It was noticeable at above 40 mph or so. It turned out there were metal shavings in the diff fluid and new gears were needed. Fortunately it was covered by the powertrain warranty.
You shouldn't be having an issue like that with a new car. I would check your differential fluid level.
I noticed the same weak "whooo" noise on mine between 62 - 74 mph (100 - 120 km/h) when coasting, I waited until I had a little over 1500 miles and changed the differential oil using Ford 75W-85 and XL-3 additive. Later I found out that this additive is only required for the Traction-Lok diffs and not required for the Torsen diff (which the Dark Horse has).
The noise almost disappeared but came back within about 600 miles or 1000 km, so I'm currently running the Amsoil Severe Gear SVL 75W-85 and that one is quiet so far. Their tech support told me to run the oil as-is without adding the XL-3. I did some slow tight turns with the windows down and did not hear any noises so it seems to work fine.
The magnet had very little fur on it at the 1st and basically none at the 2nd change. With the factory fill and the subsequent Ford oil fill the powertrain error memory had an intermittent "P1889:00:2E Differential Oil Pressure Pump Performance" error code stored but that was never shown on the dashboard. That error code has not reappeared with the Amsoil oil.
Be aware that you need a scantool to activate the diff cooler pump when changing the diff oil, I have a cheap Launch scanner which was able to do it
No, I don't think that's a good idea since you would run the risk of running it dry.
I drained the diff by removing the E-clip on the lower cooler line (where the drain plug on a GT would be) and carefully pulling the hose out of the connector letting it drain for a couple minutes, then putting it back in. A little bit of oil comes out of the cooler line, most of it comes out of the diff.
After that I filled the diff so the new oil is almost level with the fill opening and ran the diff cooler pump for a minute. Then I checked the level so it is filled to 9 mm below the fill opening with the car level. I think it should be ok if it is minimally higher like 7-8 mm below the opening.
Workshop manual says 2 qts are required for a Dark Horse but that's probably for a completely new dry system, I used about 1.9 quarts.
I did a rear fluid change on my 19 at 15k and will be doing my 24 soon.. I did the BG kit from OP Mustang and sold my 19 that had over 60k on it with zero issues. I’ll be using BG again.
Amsoil says you can use the Severe Gear 75W-85 oil without any additives, but I noticed some "rubbing" during the first two or three turns on cold days (<50°F). I removed some gear oil and replaced it (118 ml / 4 oz) with Amsoil Slip Lock, that fixed it.
