Power steering locked while driving
johne1952
Ridgewood, NJ
Has any one had an issue with thier power steering Sunday while driving all of a sudden the steering locked would no let me steering the car was in Sport mode vehicle has 12000 trouble free miles then this had the car towed to dealer was told I have to wait I purchased 2 vehicles from zMahwah Ford and this service advisor belittled me I asked for a loaner and was told they had none this guy has the brains of a nat and a lousy bed side manor too. Still have no diagnosis. And am paying $95. A day for a rental any ideas? Any one have this issue?
fishinrich
North Carolina
REV745DH24
Wow, I would be surprised that if happened to me! Sounded like ticking time bomb thing just to lock the steering wheel up if you’re going 65 or 70 mph! Please inform us all on what the finding culprit is after the inspection! Thanks!
Ryunker
Madison South Dakota
Wow this got my attention, so when it "locked up" explain more, speeds, roads, were you straight, around a corner? Please post many more details.
How did you pull off the road if you couldn't steer?
Why does the dealership owe you a free loaner vehicle?
For reference purposes, I'm attaching some information on Ford's EPAS, the Electric Power Assisted Steering; it relies on physical components, electronic connections, software and modules.
The acronyms help in understanding the Ford document. Modern cars are software and electronic-dense..
ABS - Anti-Lock Brake System
ACK - ACKnowledgment (See CAN message format, ISO 11898)
ACM - Audio Front Control Module (DACMC, Radio, CD, Speakers)
AM - Amplitude Modulated
ANC - Active Noise Cancelling
APIM - Accessory Protocol Interface Module (SYNC, steering controls, radio, NAV)
BCM - Body Control Module
BCMA - BCM (Interior, right side, near floor)
BCMB - BCM (Trunk, right side, near wheel well)
BECMB - Battery Energy Control Module B (RCM, SRS. Turns off fuel in crash.)
BLIS - Blind Spot Information System
BMS - Battery Management System
CAN - Controller Area Network (See also LIN)
CCA - Cold Cranking Amps
CCM - Cruise Control Module
CIP - Consumer Interface Protocol
CPA - Connector Position Assurance (SRS, airbag connector tabs)
CRC - Cyclic Redundancy Check (See CAN message format, ISO 11898)
DAB - Digital Audio Broadcasting
DACMC - Digital Audio Control Module-C (ACM, Radio, CD, Speakers)
DCSM - Dual Climate Seat Module (Seating Climate Control)
DCT - Dual-Clutch Transmission (Paired, electronically-controlled manuals)
DDM - Driver Door Module (Keyless Entry)
DIAG1 - A physical link, connecting LHD and RHD DLC/GWMs
DIAG2 - A physical link, connecting LHD and RHD DLC/GWMs
DLC - DataLink Connector (OBDII, GWM, both LHD and RHD)
DSM - Driver Seat Module (Seat Memory, Power)
DSP - Audio Digital Signal Processor (DSP) Module
DTC - Diagnostic Trouble Code. The fault code/s, seen by a OBDII scan tool
ECM - Engine Control Module (PCM)
ECU - Engine Control Unit (PCM)
EOF - End Of Frame (See CAN message format, ISO 11898)
EMF - ElectroMotive Force
EMI - Electro-Magnetic Interference
FCIM - Front Controls Interface Module (Center Console Push-Button Controls)
FCDIM - Front Controls Display Interface Module (FCIM Outputs)
FDIM - Ford DIsplay Module (Screen Outputs)
FM - Frequency Modulated
GENCOM - Generator Communications
GENMON - Generator Monitoring
GSM - Gear Shift Module (GT500 Only)
GWM - GateWay Module (DLC, OBDII, LHD and RHD)
HS-CAN - High-Speed Controller Area Network (1,2,3 and 4)
Acronyms (cont.)
HSWM - Heated Steering Wheel Module
HUD - Head-Up Display Module
HVAC - Heating, Ventilation, Air Conditioning
ICM - Information Center Module
ID - IDentifier (See CAN message format, ISO 11898)
IPC - Instrument Panel Cluster
IPMA - Image Processing Module A (Camera, Lane Departure)
ISO - International Organization for Standardization (See CAN message, ISO 11898)
LHD - Left-Hand Drive (DLC, GWM, LHD and RHD OBDII linked via DIAG1 and 2)
LIN - Local Interconnect Network (low-cost, low-speed, low-reliability CAN supplement)
LVDS - Low Voltage Differential Signaling
MRCMA - Movable Roof Control Module, Primary (Convertible Roof)
MRCMB - Movable Roof Control Module, Secondary (Convertible Roof)
MS-CAN - Medium-Speed Controller Area Network
OBDII - On-Board Diagnostics, Gen 2 (DLC, GWM)
OCS - Occupant Classification System (Passenger Seat Only)
OCSM - Occupant Classification Systems Module (Passenger Sitting Detect)
OLM - Oil Life Monitor
PAM - Parking Assist Control Module (Backup Assist, Parking Assist)
PCM - Powertrain Control Module
PDM - Passenger Door Module (Keyless Entry)
PMI - Programmable Module Installation
PSCM - Power Steering Control Module
PWM - Pulse Width Modulation
RCM - Restraint Control Module (Seatbelt, SRS, Crash Detect)
RHD - Right-Hand Drive (DLC, GWM, LHD and RHD OBDII linked via DIAG1 and 2)
RPM - Revolutions Per Minute
RTM - Radio/Remote Transceiver Module (keyless entry, TPMS, remote start)
SCCM - Steering Column Control Module (High Beams, Turn Signals)
SCME - Seat Climate-controlled Module - E
SDL - Smart Device Link (Infotainment connectivity protocol, apps, systems)
SIM - Subscriber Identity Module
SoC - State of Charge
SODL - Side Obstacle Detection Control Module LH (BLIS)
SODR - Side Obstacle Detection Control Module RH (BLIS)
SOF - Start Of Frame (See CAN message format, ISO 11898)
SRS - Supplemental Restraint System
SUMB - Vehicle Dynamics Control Module (VDM, Magneride)
TCM - Transmission Control Module (In GT500, a dedicated unit, attached to trans)
TCU - Telematics Control Unit
TCU - Transmission Control Unit (In GT500, a dedicated unit, attached to trans)
TPMS - Tire Pressure Monitoring System
TTS - Text To Speech
VAC - Voltage Alternating Current
Acronyms (cont.)
VDC - Voltage Direct Current
VDM - Vehicle Dynamics Control Module (Magneride)
VIN - Vehicle Identification Number
VIP - Vehicle Interface Protocol
VPWR - Vehicle PoWeR (PCM manages power needs)
VQM - Voltage Quality Module ("smoothes" voltage to components)
S650 Mustang Power steering locked while driving epas belt fail
S650 Mustang Power steering locked while driving epas input
Acronyms (cont.)
Acronyms (cont.)
How’d ya get that far into it an still keep the nails clean 😉
Right, i can kinda understand the system counter steering (trying to keep on road/in lane) and i can comprehend loss of power steering making it more difficult to steer at low speed but having it lock would be disastrous.
Deleted member 63380
Guest
And my wife wants something with more power than an S650 HeGoBoom! Seems like they're plagued with too many problems. Maybe I'll go S550 GT-PP, Bullitt, or Mach I. 4 grand more for a 25 just doesn't cut it. Forget 26. Or could it be many workers at Ford plants partake in Happy Smoke and fail to do their job correctly?
:giggle:.
I downloaded that pic from another Member's post, either here or at the 6G site.
I hoover up stuff like that all the time. So many people post great examples of topics. :like:
Reactions: Zig
Updating some items for my stash, posting them here.
In the first photo, an entire EPAS rack assembly. The motor is most forward. The belt drive, to the left. Steering column tie point, to the right. This is a Ford rack, not necessarily one for a S650. Disregard any PN# references.
In the second photo, what a belt drive looks like, assembled.
Notice the linear screw, for quicker, more precise control versus legacy steering linkage.
Refreshing my training on the topic, there is a "manual" mode for these systems, a fail-safe. If the unit fails, the driver should be able to continue to drive the car, with legacy, manual steering. I'd like to think that's what happened in this example. I hope we can find out more once the dealer has had time to diagnose the problem and propose a solution.
S650 Mustang Power steering locked while driving epas rack complet
S650 Mustang Power steering locked while driving epas belt exposed
Ryunker
So what happened to this member? Wonder how real their problem was?
User only has one single post on these forums, claiming their steering "locked up" WHILE DRIVING and wouldn't allow them to steer, but won't come back to answer questions or clarify. Hmmm ...
