Mustang hits rev limiter at 6000 Rpms while driving.
94.los
Bay area CA
2024 mustang GT Performance pack
Just recently i noticed my mustang hits the rev limiter at 6000 Rpms when i step on it. It is a 6 speed MT and does it on and off, it feels as if the car hit red line while driving and sometimes the auto rev match does not work. I'm going to replace the clutch safety switch as i read somewhere it could be the issue, i did notice the clutch safety switch makes noise when i press the clutch, and its not the spring itself as i have replaced it in the past. Wondering if anyone else has had this issue? I will update the thread after i replace the clutch safety switch to see if its resolved or not. Thanks all!
94.los
94.los
Bay area CA
Are you out of warranty?
Nope, going to try this before i take it to the dealer, service sucks, i took it in for the noise in the clutch spring and they told me there wasn't anything damaged so there's nothing else they could do. Don't want to leave my car there for a couple of days just for them to tell me they couldn't find anything.
Ewags81
Midwest
2024 dark horse
got to be an open/close switch. check it with an ohm meter before replacing. as bad as my trust issues are, id probably still hesitate to replace electrical components on this car myself without ford consent. its all linked to the computers.
94.los
94.los
Bay area CA
Gotcha, ill try the Ohm meter! yeah i feel you I'm the same way, but im buying this straight from the dealer its a oem ford part and its completely plug play, i'm really hoping this fixes the issue, even if not i hope the noisy clutch goes away, its been doing it since i first got the car.
Boca 5.0
Boca Raton
25 Dark Horse 6 speed, Z06 mid-engine, F250
I have the same, exact problem! Intermittent. Does it in all modes. Almost dangerous as you don't expect the car just to "quit"
ZXMustang
tooner
TC light flash? Maybe tq management stepping in. Thats a weird one. I would only assume it was one of the temp rev limiters since there are several. But under normal acceleration it shouldnt unless you were on track or something hot lapping.
94.los
94.los
Bay area CA
I wonder what it could be? Have you done any mods?
94.los
94.los
Bay area CA
No tc lights at all, it does it on and off, and the temps seem to be normal so i don’t have an idea
Ive heard of this happening on manual cars.
GooberDH
2024 Mustang Dark Horse
Power seems to take a nosedive with my Dark Horse at WOT before redline. Traction is fine, clutch doesn't seem like it's slipping. I know the manual redlines at 7250, not 7500 for "reasons". I haven't been winding out the engine often enough to see if there's a pattern.
94.los
94.los
Bay area CA
my mustang completely shuts off before hitting 6000 RPM's as if it hit redline, it does this intermittently, not like a loss of power but more of a complete engine shut off.
Any idea what it could be? my auto rev match stops working every now and then intermittently
No idea. But it appears the rev limiter is set lower on manual cars. Im not sure if its the speed or the gear its in, but some scenarios drop it to 6k.
I'm refreshing myself on the following threads.
There's an absolute hard limit that all engines have. This limit cuts fuel to the engine.
Several mention in these threads the Manual Transmission cars have a hard limit 2-300 RPM lower than the Automatics. I suspect this is because of shifting, clutch release, human moving the clutch pedal, sudden, unloaded engine etc.
Engines also have a soft limit. This limit is based on oil and Cylinder Head Temperatures, so it's more variable. Timing, maybe fuel, are manipulated by the Powertrain Control Module to slow the pace of the engine's acceleration. It's not abrupt like a hard limit.
[Edit, In a stock setup, soft limits engage before hard limits. The hard limit is the highest RPM an engine will spin, regardless of condition. The soft limit looks at other variables, primarily temperatures, and realizes its best to slow things down before reaching the ultimate redline.]
So differences of a few hundred RPM between transmission, yes. Engine cutting out at 6,000 RPM? I suppose that's possible, if they were seeing some high temperatures. If the temperatures were more "normal", around 190 F / 87 C, the engine should go right to 7,500, or thereabouts.
The OP mentions temps are normal when these events occur.
Could be a bug in the software of the PCM, something Ford hasn't become aware of. But I'd think we'd be reading of it more often? These engines use a Throttle Position Sensor. I wonder if one of those acting up could make these events occur.
For cars which have been tuned, sometimes, the tuner updated the limit tables by mistake; this is also discussed in some of these threads. Tuners sometimes remove protection of the soft limits. Or they confuse the soft and hard limit tables.
https://www.mustang6g.com/forums/th...-lower-rev-limit-on-manuals-than-a10s.203939/
https://www.mustang6g.com/forums/threads/why-do-i-only-get-7200-rpm-instead-of-7500.196936/
https://www.mustang6g.com/forums/threads/red-line-rev-limiter.134568/
https://www.mustang7g.com/forums/threads/where-in-the-rpm-band-are-you-noticing-fuel-cut-off.158795/
https://www.mustang7g.com/forums/th...in-the-5-0-with-a-manual-transmission.160710/
https://www.mustang6g.com/forums/threads/mustang-gt-2022-manual-rpm-redline-7000.186964/
