Doug Watson
I've got the Steeda jacking rails on my DH and had them on the M1, love them.
sdsteele2
Tennessee
24 Mustang GT
I installed the LMR/SVE jack pads on my car. They are very convenient for lifting a single wheel for cleaning or swapping out tires. They also work great for a 2 post lift.
One downside is they don’t help if you want to put a jack stand at the factory lift points. Your jack will be in the way. Or at least mine is.
https://lmr.com/item/SVE-2024JP-K/sve-mustang-jack-pad-kit-2024
Jmatech
Tennessee
2034 Mustang Dark Horse
All I purchased for the mustang were the pinch weld blocks from quick jack. They have slots that fit perfectly under the mustang lift points. I ordered it all from Home Depot.
Right on, thank you!
tj@steeda
2015 Steeda Mustang
Deleted member 17846
Guest
I have the Steeda Jacking Rails and consider them a must have if you work on your own Mustang.
I also had the QuickJack 7000, it was good but heavy as hell. Loved it for the F150.
I found it much easier to use the Steeda Jacking Rails with good jack stands or Race Ramps Wheel Cribs for the Mustang. Ended up getting rid of the QuickJack.
TX-TBeau
Round Rock, TX
2025 GT 5.0 6MT, 2018 Accord 1.5T 6MT, 2018 WRX 2.0T 6MT, RAM 1500 5.7 Hemi
My question is, so if you jack up with a floor jack, from the correct lift points, where do you place the jack stand?
I purchased AGM jack rods. They lock a floor jack to act like a backstage. I use them in pairs with 2 floor jacks to lift front/rear or side, depending on the work. Wish I had a lift, but jack rods are great.
Nolasalt
NOLA
2024 Mustang GT & 2010 F150. Past rides: '83 GT, '88 LX, '95 Cobra
My previous 3 Mustangs I've always used the middle of the front K member to jack up the front of the car. Is there some special reason the metal on my S650 makes this no longer possible?
S650 Mustang Jacking / lift points copy1
exm
Long Island, NY
There are little cut outs in the plastic side panels under the sides near each jack point for jack stands. The jack points have little arrows in the plastic panels. Jack stands go in near the jack lift points .
Sorry to resurrect an old thread. I need to jack up the rear off the car (DH) to work on some LED lights. I'm seeing the cut outs with the arrows. No problem jacking up the car there. But where to place the floor stands? It doesn't fit next to jack. From what I gathered is to jack up the car near this area (preferably using Rubber Slotted Frame Rail Protectors) and then place the floor stand where the 'arrow' is - the jack point). Or do I need to do the opposite: use the jack point for the actually jacking up off the car, and then place the floor stand with the protectors near this?
I considered jacking rails but I haven't seen any that fit the DH without any sort of modification. Also, I am probably done jacking the car after this maintenance so the rails will be one-time use.
Will2
'26 Mustang GT
For my fellow OCD perfectionists, I've found that many rubber jack pads are not deep/tall enough to fully prevent pinch welds from cutting through (and contacting the metal of the jack cup, thus scratching the paint on the bottom of your pinch welds). Same thing with those metal pinch weld adapters--those often have an exposed metal piece at the bottom of the channel (to secure the nylon guard that runs through the channel) which scratches your pinch welds.
I wonder why manufacturers don't just make them slightly taller/deeper, and I suspect it's because if they made them taller, there might be too much side-to-side flexion and the item could slip off the pinch weld.
I have now ordered polyethylene jack pads from Amazon. They are harder than rubber so should not get cut through, but still soft enough to not damage pinch welds. We'll see if that actually works.
I wish Ford made a simple lifting solution for DIYers, or even plastic lift points that could be replaced if/when worn out (like BMWs and Teslas).
exm
Long Island, NY
You are still talking about the protection for the pinch welds (and no issues there), but my question was where to place the jack and the floor stands?
