Help please, 2024 coyote Procharger P1x post install gremlin
Keith T
Rhode Island
S650 spec II RTR
Hi, I'm having a major problem with complete power loss under load.
It started approx 500 miles after the P1x installation. One night I got on it and the car completely fell on its face, the instrument cluster went out and the car started downshifting immediately. It stayed running, the cluster came back on immediately but it switched to normal mode from track mode. Car runs and drives around town just fine.
Took it back to the shop that did the installation for him to do a once over of all the connections. My suspicion is that the car is either losing voltage via bad plug connection or it's a ground. Never the less he didn't find anything. I took it home and got into it a few times and it was fine. Final time I gave it gas the car started misfiring and shaking. I immediately headed towards the breakdown lane and the car continued to sputter/misfire. I checked the oil along with any other signs of apparent damage and all checked out.
Decided to start the car and it ran completely normal. I nursed it home and it ran fine. I'm looking for ideas as to where this connection that is failing may be. Hoping someone has experienced this before. I pulled the codes on the Procharger handheld, they're all related to misfires, canbus losing connection with ECM , battery voltage.
S650 Mustang Help please, 2024 coyote Procharger P1x post install gremlin Screenshot_20260704_205433_Googl
S650 Mustang Help please, 2024 coyote Procharger P1x post install gremlin IMG_20260704_205713
S650 Mustang Help please, 2024 coyote Procharger P1x post install gremlin IMG_20260704_205705
D/\rK•650
2025 Mustang DarkHorse
Im sorry I don't have any answer for you as forced induction is something I don't know much of. These cars can be extremely fininicky with battery voltage being low or bad batteries. Maybe put your car on a tender and check the voltage make sure it's normal and not low. Hope you get everything working.
Neggytive
Belt slipping, causing voltage drop, freaking the computer out?
Keith T
Keith T
Rhode Island
S650 spec II RTR
Anything is possible but that would be lower on my suspicion list. Car has 3k miles on it, belts and accessories are practically brand new. I really think this is coming down to a connection problem. My installer is just going to have to take the car in and spend time investigating. I'm thinking with auxiliary power on pull on some harnesses, ground cables, twist the engine with a pry bar etc to try and duplicate the problem
ZXMustang
tooner
2025 ESS G3 Mustang GT
The lost comms DTC is from flashing the tune. Should clear with a code scanner. I see these every day after flashing tunes. First thing we do after a flash it start the car, then immediately clear the DTCs to clear out that and a few others that are normal.
Keith T
Keith T
Rhode Island
S650 spec II RTR
There were no codes until the car reacted like it did. Lost coms could be from lost power/signal also from what I've read
