JPGC_S650
- Joined
- Sep 28, 2020
- Threads
- 7
- Messages
- 193
- Reaction score
- 203
- Location
- Anderson, SC
- Website
- www.youtube.com
- Vehicle(s)
- 2024 Mustang GT, 2022 HD Road King Special
Yep, completed this as per the recommendations in the instructions.
"8. Using a coil spring compressor, compress the front spring until there is no tension on the upper strut mount. Once the spring is safely secured, remove the nut holding down the upper strut mount. Then, separate the strut from the spring and the upper strut mount. Carefully release the stock spring, and compress the new Steeda front spring. At this time you should determine if you’re going to trim your bump stops. Steeda recommends trimming 1/2” from the front and rear bump stops (1/4” - 1/2” with “Active” dampers), picture 8 (Steeda recommends our Adjustable Bumpstop Kit 555-4445). When putting the assembly back together, the larger diameter (ID/opening) of the spring should be upward and each pigtail should be against the spring stop. See pictures 6-7 for more information. It is very important to use Red loctite on the swaybar endlink studs and nuts mounting to the swaybar end. This will prevent them from coming loose."
Make sure that you only trimmed the bump stops no more than a half inch.
If the bump stops are trimmed more than a half inch or are compromised , it will cause noise on sharp bumps.
Steeda Tech
[/QUOTE
