Forscan for beginners?
DT-GT
2022 Mustang
Seems. Easy enough. I'll get the cable and give it a try.
Is the seat belt display when you start the car something you can disable in easy mode by chance?
DT-GT
2022 Mustang
I would love to get rid of that using a simple procedure that doesn’t impact other things. But the info I’ve seen posted does not seem to fulfill that desire.
Paul2020
Paul2020
Australia
2024 Mustang GT Atlas Blue
Thanks guys. You didn't have any issues or errors afterward?
The only issues i had was as per my comments at start of this thread, but they seemed to have sorted itself out next time i started the car. No problems since.
Was this using the "easy" method of enable/disable?
DT-GT
2022 Mustang
Just a thought. Any chance those problems could have been the result of the battery going into the battery saver mode. If doing lots of settings, programming etc with the car not running it pulls lots of power from the battery. The symptoms sounded battery suspicious. Just curious.
Paul2020
Paul2020
Australia
Was done using Easy mode.
Issue could of been caused by battery going into the battery saver, only the car knows.
I did have the car on (not running) for a while, while playing around. Wouldn't surprise me as it did change some settings as though I disconnected the battery
Will see how I go next time updating something.
Would like to get a pic of all the changes possible in each module so can go through them in my own time rather than sit there looking while car on..one day.
