Ford Says It Makes 500 hp, Four Different Dynos Give Four Different Results
D/\rK•650
2025 Mustang DarkHorse
The motor I'd bet makes 500hp. It has to be in Fords performance engine cradle. Then absolutely it is 500hp motor. 🤔. All motors can vary alot based on lots of variables. Right?
Neggytive
Dyno's measure torque, the HP number is extrapolated, and different machines have different smoothing corrections added on.
They are a great tool to do timing as in add timing until the torque gains stop then back it off a degree or two, or looking at A/F ratios which is why it is said time for torque, jet for HP.
But for comparing different engines against each other it is a crap shoot
There have been guys on TV ( Engine Power, Engine Masters) who have built identical engines and run them as close to same conditions as possible ( oil temp, water temp, density altitude, etc etc etc) and never gotten the 2 engines to give the same data
If you get the same data,for one engine within the range of variance / tolerance of the machine you are doing good. When you can replicate the data it is considered valid
Getting 2 or more engines to come out the same on any given dyno is unlikely IMHO
These are not engine dynos. It should not come as a surprise that the numbers came out all over the place.
They must not have anything to write about over there. Three of the four dynos were within 10hp, nothing wrong with that. That Mustang dyno needs fixed.
Superflow420.8
Dynapack430.9
Dynojet425.7
Mustang465
135Hoser
2024 Dorkhorse, 2024 CR-V
Stupid click bait headline with the actual truth half way through the article after a dozen ads, that dynos are only useful to measure a gain after modifications are made assuming you have a baseline.
