Ford Performance not offering the 4.09 gears for the 2024. Why?
ThreePedalPlow
Saint Louis
Agreed, 3.55 to 3.73 is minimal. Thats a 5% bump.
You could get close to that with slightly shorter tires.
4.09 gives you 15% extra.
THats 40 to 45lbs at 2500rpm
60lbs at peak 400 rpm
Old S550 procal would allow 4.09 gears.
I'm guessing once the S650 procal is out, 4.09 will be offered as well.
I assume you are talking about lbs of torque. What did you mean by "60lbs at peak 400 rpm"?
ThreePedalPlow
Saint Louis
What RPM do you guys think you would be running on the interstate traveling around 70 mph when you are running a 4.09 gear in a Getrag? I'm wondering if it would be obnoxious on the highway.
RBGT
BC
S650 GT Premium, 6 spd
should be 15% higher than 3.55.
So if its say 2500 with the 3.55, it will be 2875.
RBGT
BC
From another forum:
" 'll use myself as an example: At 70mph with a 3.55 rear gear set, I am turning 2202 RPM "
so with 4.09 it will be 2530 rpm
RBGT
BC
Given the MT82 was a 6th gear ratio of 0.622, thats very low.
Meaning highway RPMs will be nice and low.
Should be fine with 4.09 gears.
Pretty much brings things back down to the old MT-82 ratios
First two are 3.55, last one is 4.09
It does lower your 4th (1:1) gear top speed from 160 to 140 though. the 3-4 is going to kind of suck like it did with the old wide ratio t56
Would like to hear from supercharged S550 owners if moving to 4.09's is worth it or not
(chart shows gear ratio and mph @ 7200rpm so add a couple mph to get say, mph @ 7500rpm)
S650 Mustang Ford Performance not offering the 4.09 gears for the 2024.  Why? Screenshot 2024-09-06 at 11.08.38 AM
Mr Hyde
florida
2024 mustang GT
I see how that would be beneficial. Didn't realize the ratios were so different across years.
Dave2013M3
Dave2013M3
El Segundo,Ca
Neggytive
JasonX
2024 Yellow Splash 6sp PP
@LevittownFordParts is showing M-4209-88410 for the 2024 which is the FP 4.10 gear set
You will need the install kit to go along with this part to do the install and get the pinion depth set correctly.
FYI buy an extra crush sleeve just in case
https://www.levittownfordparts.com/sku/m-4209-88410.html
Oh interesting, thanks, so the pinion gear and crush sleeve just incase, thanks!
Going to get this ordered soon and installed, wonder what horrible codes it will throw lol.
Neggytive
you are going to need the install kit that goes with it
https://performanceparts.ford.com/part/M-4210-B3
It will have the bearings, shims, seals, crush sleeve and all the other parts you need
Don't forget gear oil and limited slip additive. ( M-19546-A12 )
As for codes, you are going to have to reset the speed sensors so the odometer reads correctly, and there is a flash for the transmission to get the shift points right for the lower gears value
It is a lot easier to spend the couple of bucks for the spare crush sleeve than to find out you rammed the pinion nut down too far, screwing up your bearing pre load and saying eff it it will be fine ( it won't)
Dave2013M3
Dave2013M3
El Segundo,Ca
